My refurbished Booster
Hey Guys, Every little step and progress that is made is a thrill so I thought I'd share my budget Booster refurbish. I bought it on ebay and then soda blasted it to bare metal. Then rattle canned a primer coat and topped it with Rustoleum's hammered finish gold paint. I didn't want to spend the money on having that cadium finish and am really happy with the way it came out.
Anyone know where I can get a new rubber boot that goes towards the firewall. Can you also get a new vacuum plug? Heres how it turned out:
Alex 1971 Lil' Red 350 SBC 700R4 |
#2
RUNN over AGAIN!!!
looks good
67-72 TRUCKS ROCK 70 SWB shaved and a 72 front clip.and a poly tank. Peep mirrors and a BIG BLOCK 468 in the making. XNXNXNXNXNXNXNXNXNXNX ,/. EMAIL ME HERE!, Dont pm me please ,/. |
#3
Designated A-hole!
Get the vacuum plug (check valve) in the HELP section at autogroan.
Looks good!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#4
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 04-28-2004 at 03:41 PM. |
Great job!
#5
Last one :
good luck finding that rubber boot, I never did find one when I did mine. Let us know if you do find a source!
oh yeah... that looks good! ![]()
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban ![]() Endeavor to persevere. "All of a sudden, I'm the old timer!" Some old timer on American Pickers. |
Well I do believe I may have found a source.....Chevy Duty part # 71-298 for $6.95 called Power brake push rod boot.
Looks sweet, real nice job! Wish I could find a source for the silencer (felt) that goes inside that boot.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
#13 |
The boot shown in the picture is not correct. I bought and tired the same boot when I basically did the same thing as you. After I got it I found it wasn't right. I reused my old boot and made a new silener / filter out of a piece of foam
#14 |
Wait a sec, your booster looks a fuz different where the boot attaches. Maybe that will work on that booster?
Do you have a close up of the sleeve where the boot goes on? |
#15 |
Try spinnin 4 rear tars
That is the wrong boot for the hole in the firewall. The boot pictured above goes in the spot where the black section is on the 'firewall' side of the booster in pic #5. I have never been able to find the boot that goes in the hole of the firewall to make a seal on the rod from the brake pedal.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
#16 |
This is the correct brake rod firewall boot available from Golden State Parts, $6.95.
#17 |
Looks really good!! Lots of good resto info popping up too.
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
#18 |
**************** also sells the correct brake rod firewall boot. I looked High and Low, then he had my answer. It wasn't too expensive either.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#19 |
Here is a close up of the booster back where the rubber boot goes. I have not tried yet...but I believe the rusted ring must un-screw or pop off. Then the rubber boot would go on and rusty ring holds the boot in place???
#20 |
another close up:
#21 |
Well I was sort of right. The rusty ring does come off and holds the boot in place but does not screw off. It is just pressed on and has no threads. I put a set of channel locks on it and turned it to the left thinking it had threads. It came right off easily but has no threads. You know I'm going to sand it down and paint it...don't cha??? Here is a pic of it removed:
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 04-30-2004 at 11:23 AM. |
#22 |
TTT , just in case anyone missed that the ring does come off to hold on the missing rubber boot!
Thread Tools | |
Display Modes | |
