Old 04-30-2004, 03:10 PM   #1
Russell
Professional Grade
Russell's Avatar
How many bolts?
How many bolts are there holding a bed onto a truck?
As far as I can see, there are only four on my truck, two in the middle of large rot holes... lol
So basically all I gotta do is pull my fuel filler hoses off, the tailight wiring and lift it off after taking out the two bolts that are still in somewhat decent metal?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-30-2004, 03:33 PM   #2
Jonboy
Slots go on anything!
There should be 8 bed to frame bolts. If yours are rusted that bad, just cut them off.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-30-2004, 04:00 PM   #3
Gibble
mmmm....Rye and Coke
Gibble's Avatar
The rear diff has a breather hose bolted to the box as well...
Gibble is offline   Reply With Quote
Old 04-30-2004, 05:50 PM   #4
Low87
been here longer than Liz
Low87's Avatar
8, 2 towards each corner lined up on the frame.
When I first pulled my bed (I've done it 4 times now) I threw away those 7 PITA short bolts that only go through the top of the frame. Bought 7 of the 1 long bolt that goes all the way through the frame to make it easier to reach the bolts. The holes are already in the frame.
Now my problem is that one of the square holes in the bed where the carriage bolt rests is rounded out, makes it near impossible to tighten that nut.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 04-30-2004, 05:52 PM   #5
shavedchevy
shavedchevy's Avatar
my bolts are welded down on the top from the previous owner. PITA to get the box of and on but you can really snug the nuts up good
Dennis
shavedchevy is offline   Reply With Quote
Old 04-30-2004, 05:55 PM   #6
Russell
Professional Grade
Russell's Avatar
What I've had to do is grind the tops of the bolts till I can hammer them down the shaft then grind through the bottom half. Now I've come up against another problem -- My muffler is blocking two of them, and I can't get my angle grinder in there...
Sigh, lol
I've never lit my hair on fire so many times due to grinding sparks :P
Old 04-30-2004, 05:57 PM   #7
Low87
Low87's Avatar
Welcome to the world of custom Chevy trucks.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 04-30-2004, 06:04 PM   #8
Russell
Professional Grade
Russell's Avatar
I rather like it Feels good to be doing something major!
Old 04-30-2004, 07:34 PM   #9
Jonboy
The hot wrench will make quick work of the bolts.
Thread Tools
Display Modes
