Old 05-03-2004, 10:31 AM   #1
M5Yates
Need Differential Advice
We let the tranny fluid get old and low on Grandpa’s 1954 3100 5-window. The transmission bearings let go. After rebuilding the tranny (3-speed manual), the mechanic inspected the differential and said it needs to be replaced. There are grooves in the gear teeth and the bearings are shot. He says that rebuilding the differential is difficult and it would be cheaper to replace it with a used unit. That would include the pumpkin and the attached drive-shaft.
This is a nice original truck with only 35,000 miles, but is there any alternative to using the diff from another ’54? Is a rebuild that difficult? (I understand that there are some leather pieces.)
Thanks,
Bill Yates
Austin, TX
M5Yates is offline   Reply With Quote
Old 05-04-2004, 04:23 AM   #2
rebarjoe
I just looked at a sectional view of a rear and see no leather parts you refer to. I think the only difficulty in rebuilding will be to get the gears. The bearings will probably be the easiest to get. If you can get all the parts I'm sure it will be kind of pricey to rebuild. Maybe your best bet is to get a used unit with good gears. I had the rear on my '70 Ford p/u rebuilt about 10yrs ago and it cost $500 then. Get the numbers off the bearings and see if they are obtainable. Try NAPA, they might even have a ring and pinion. Obsolete Parts in Nashville, Georgia might have the parts also. Good luck
Joe
'49 GMC 100
'70 Ford F100 351m/400
'95 GMC Jimmy
'98 S-10 4.3 Vortec 5 speed stick
rebarjoe is offline   Reply With Quote
Old 05-06-2004, 09:58 PM   #3
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
visit Chevy Duty pickup parts website
You can download their catalog. See page 7 Part#05-511 "rear axle overhaul manual" $5.99
Page 76 Part#93-5111 "axle gears" (3.55 ratio only) $399.95
Page 76 Part#93-512B "install kit" (Bearings, bushings, gaskets, shims) $274.95
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 05-06-2004, 10:23 PM   #4
M5Yates
Chevy Duty
I called Chevy Duty this morning. Their 3.55 gear set is described as "bolt-in". I spoke with the tech and he said it was an easy job, it just took a long time. Well at $75 an hour, I don't want my mechanic doing "easy but long" work.
We found a used diff in North Texas for about the same cost as the new gears ($400 plus shipping). Thanks all for the advice. Now I've got to get the speedometer working again.
Old 05-27-2004, 04:08 PM   #5
solidaxel
solidaxel's Avatar
Why did you not change the rear to a Camaro or Monte Carlo the Monte is the right width. Did your truck have a open drive shaft?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-27-2004, 04:17 PM   #6
M5Yates
That's the first time I've heard of an alterative to the original diff. I wish you had seen my request earlier. The drive shaft runs through a tube.
Thanks,
PS The truck is now for sale.
Old 05-27-2004, 04:42 PM   #7
solidaxel
solidaxel's Avatar
Bill, I sent you a P M
LS 3 4L70E
Old 05-27-2004, 05:45 PM   #8
M5Yates
'54 Chevy 3100
Here's a listing: http://tinyurl.com/2wlo4
I'm asking $12,900.
Thanks,
Thread Tools
Display Modes
