Old 05-12-2004, 01:30 PM   #1
UP GRADE
one set closer
UP GRADE's Avatar
Sandblaster
I WOULD LIKE TO SEE PICTURE OF SOME SANDSLASTER AND WHERE DID YOU GET IT FROM. I'M THINKING ABOUT BUYING ONE IF THEY ARE NO TO MUCH.
UP GRADE is offline   Reply With Quote
Old 05-12-2004, 02:35 PM   #2
sider68
sider68's Avatar
maybe if you ask Dubie,he will send you one.Be sure and buy a pressure feed as the siphon ones waste too much sand.Depending on what you are doing it might be just as cheap to get someone to do it for you.
sider68 is offline   Reply With Quote
Old 05-12-2004, 05:30 PM   #3
neonlarry
neonlarry's Avatar
Check out this place http://www.tptools.com/ they even have a do it yourself kit.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-12-2004, 06:12 PM   #4
Pont
I need another Barley Pop
Pont's Avatar
Just a sandblaster or a sandblasting cabinet? Here's my cabinet from I believe Northern Tools. Paid $299 for it.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 05-13-2004, 02:11 AM   #5
454_72_4X4
454_72_4X4's Avatar
The cabinet is the way to go for smaller stuff.
I built my own pressure feed blaster a couple of years ago and just got to use it for the first time about a week ago. Works good but I need a bigger compressor to keep up with it now.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 05-13-2004, 07:05 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I have two blasters. One is a cabinet type and the other is a pressure type. Both came from TIP tools (see link above in the other guy's post). This brand may cost a little more, but you won't be sorry.
Old 05-13-2004, 07:32 AM   #7
MACKL
Almost done!
MACKL's Avatar
I bought a cheap blast cabinet from harbor freight. About $100. The angle of the gravity feed hooper is not steep enough and you have to manually rake the blast media to the pick up tube. It is for sale! Will deliver.
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Thread Tools
Display Modes
