Old 05-12-2004, 04:25 PM   #1
Piper71c10
Unending Project
Piper71c10's Avatar
Help With Lights?
this is for my '64, but I'm guessing the wiring is the same...
So... My turn signals work, but only when the headlights are on. My brake lights and parking lights don't work at all. When the headlights are off, the turn signal flasher still sends juice to the bulb, but only enough to barely light it up (not visible through the lens).
Any thoughts? Could be my headlight switch?
Piper
Piper71c10 is offline   Reply With Quote
Old 05-12-2004, 04:33 PM   #2
Sweet72
Sweet72's Avatar
Sounds like a poor ground. Check to see if the bed has a bonding wire going to the frame anywhere, if not, attach one and your lighting problem will likely go away. You can just use some 10 ga. primary wire with terminal lugs crimped to both ends.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 05-12-2004, 05:15 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Start with a new ground wire, see what that does. Don't even bother looking to see if the stock one is there. installing a new onw will remove all doubt.
Old 05-12-2004, 06:02 PM   #4
Piper71c10
Unending Project
Piper71c10's Avatar
Thanks... I'll give it a shot.
Old 05-13-2004, 01:43 AM   #5
Hooter
My other Love
Hooter's Avatar
chances are if it has a wood bed, you need that ground, if not that I would check to see if there is corrosion in the sockets, is it a real rats nest of wiring in the 64?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 05-13-2004, 11:53 AM   #6
Piper71c10
Unending Project
Piper71c10's Avatar
No, Surprisingly the wiring is in great shape. I cleaned the sockets with a wire brush when I checked the bulbs, and even replaced one. I haven't gotten around to trying the ground yet, been busy welding the patches into the door handles. I'll try that first thing today tho.
Piper
Thread Tools
Display Modes
