Old 05-14-2004, 03:05 AM   #1
Dwaynes56&68
4 inch lift and drivelines.
What luck I have. I bought Tuff country 4 inch easy rides front and rear for my 78 shorty. Now, my stock springs were collapsed a bit from age but not to bad. But the new springs jacked me up 7 1/2 inches. My drive shaft in the front will not rotate without binding and the rear has about 1/2 of splines showing out of the slip yoke. Anyone else have to modify there drivelines with a 4 inch lift? I even double checked the part numbers, they are 4 inch springs. This blows.....
Are we there yet?
Dwaynes56&68 is offline   Reply With Quote
Old 05-14-2004, 03:36 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I got about 3"+ from my 2" tuff country front springs. Make sure you have not pre-loaded the bushings, that is don't tighten the shackle bushings until the full weight of the vehicle is on the springs.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-14-2004, 11:00 AM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
On my 69 K20 I had to lengthen my front driveline and add a CV joint. Sound like you definitely need the CV joint. That is really odd you got so much lift - I would consider exhanging them if you don't want to be that high.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-14-2004, 01:03 PM   #4
ryanroo
ryanroo's Avatar
almost 8 inched seems like an awful lot out of 4 inch springs, but i get nearly 11 inches from my 8 inch lift, i just assumed they would settle out as they got used. good luck
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-14-2004, 01:14 PM   #5
LONGHAIR
The 78 should already have a CV joint. They will have to be "clearanced" for anything over about 6". You will need to grind the little square bosses off of the yokes and maybe a bit more of an angle from the edges too. Don't go crazy or you will weaken the whole thing.
You really shouldn't need that for 4" though. Even if you truck was sagged a lot, it should still only be approx. 4" above what should have beend stock.
So even if it did lift you more than 4" from where you were it shouldn't be high enough to cause clearance problems with the CV joint yet. You never know though..........too many variables.
If it is too high, send them back. Otherwise you HAVE to do something with both of those shafts.
It will be far cheaper to go to an "auto recycler" and get a rear driveshaft from a LWB truck and have it shortened. Shortening is far cheaper than lengthening.
LONGHAIR is offline   Reply With Quote
Old 05-15-2004, 12:36 PM   #6
Dwaynes56&68
I am going to go buy a 2 1/2 lift. I spoke with a tough country rep and he said that overall it should settle about 1/2 inch after they are broken in. They had me measure the free arch of the springs to confirm they were correct and they are 4 inch. It looks really funny to with 255/ 85 /16 tires, which work out to about 33 inch.
Are we there yet?
Thread Tools
Display Modes
