Old 05-15-2004, 08:12 PM   #1
Steve Beecher
bad brake booster on 68/C10?
Hi Guy's..
I suspect my 68/C10/350ci w/ power brakes has a problem with the brake booster. Here's what happens'..sometimes when i apply the brakes hard not only does it seem like there isn't much stopping power, the engine will start running rough after i let off and get back on the accelerator pedal. I've checked for vacuum leaks arond the carb, etc. and nothing was found. I tested the booster the only way i know by removing the booster line to the booster from the intake manifold after shutting the engine off and letting it set for a couple minutes..it seems to holds vacuum?..This problem is driving me nuts!! I've come here before and y'all have been most helpfull.....thanks!
Steve
Steve Beecher is offline   Reply With Quote
Thread Tools
Display Modes
