Old 06-01-2004, 01:02 PM   #1
sweet n rare67
Young truck fanatic
sweet n rare67's Avatar
Blazer tank under truck bed???????
I am considering putting a poly blazer tank under the bed of my truck. What modifications do you have to make for this to work and fit properly? I would also like to see pics of this.
'67 Chevy Longstep 2wd 350 w/4spd manual Muncie M21. My first project.
**Proud to be Valley Trash**
sweet n rare67 is offline   Reply With Quote
Old 06-01-2004, 01:12 PM   #2
busterwivell
The toughest part is the filler neck issue. I went to a Marine Supply and bought one and mounted it in the wheel well. Works fine for me. Sorry, I don't have digital camera. Some people have complained about poly tanks, but I haven't had a problem with mine in the 1 and a half years I've had it in.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 06-01-2004, 09:01 PM   #3
67cst
i love summertime
67cst's Avatar
busterwivel---where did you get your marine filler? is your blazer tank filler spout 1 1/4 inch? mine is and the marine stores around here only have 1 1/2 and up...im having a hell of a time locating something
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 06-02-2004, 12:46 AM   #4
67shortie
Green club
67shortie's Avatar
I installed my tank this weekend.
To get it to tuck under the frame right I sectioned out the bed's rear crossmember 2 inches (steel floor) and welded a piece of steel in it's place for strength. I also bolted it up on the rearmost holes (had to drill 2 and grind off the tabs that 'locate' the factory blazer unit, mine is a metal tank) Looks great, just need to finish it up this weekeknd coming up.
I have not yet run a filler location or tube yet, so sorry I can't help you there.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 06-02-2004, 12:49 AM   #5
67shortie
Green club
67shortie's Avatar
Also, if this marine filler has a steel neck, one could possibly weld a reduced cone flange to it so you could pop a 1.25 inch hose on it? Just a thought, I will be going through this same problem very soon.
Old 06-02-2004, 02:31 AM   #6
Mudder
Mudder's Avatar
I brazed a copper elbow onto my marine filler. It was the correct sizes on each end and got it going in the right direction.
Mudder is offline   Reply With Quote
Old 06-02-2004, 12:11 PM   #7
busterwivell
67 CST, I had the same problem with the hose ends. I made a spacer over the smaller end out of hose and then clamped it all together. hasn't been a problem.
Bill - Tucson, AZ
01 Chevrolet Tahoe
Old 06-02-2004, 12:54 PM   #8
Jwill41
Jwill41's Avatar
I have a filler neck from an 80's model saddle tank. I have it mounted under the drivers side fender.(stepside) It works real well.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 06-02-2004, 01:07 PM   #9
71swb4x4
71swb4x4's Avatar
http://67-72chevytrucks.com/vboard/s...d.php3?t=74876
Here is jorgensensc's install that is posted in the FAQ section.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-02-2004, 08:23 PM   #10
Blue4x4
Blue4x4's Avatar
here are a few picks of what I did. Used the poly tank from LMC. And a subaru filler neck. Fill location is behind the blinker. I had a louvers punched in the protective plate as moisture was collecting in it. I also had it powered coated. Total cost of everything......$450.00
Blue4x4 is offline   Reply With Quote
Thread Tools
Display Modes
