Old 06-01-2004, 01:08 PM   #1
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Proper Rally Lug Nuts?
Anyone know what the proper size and style of lug nut should be used? These are 5 lug Truck rally's.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 06-01-2004, 01:43 PM   #2
crazy longhorn
Fabricate till you "puke"
they are 1/2" 20 thread, & the steel wheels have a 60 degree taper on the seat. I dont know if correct, or not but they look good....i got a set of acorn style chrome nuts at Advanced auto parts($28 for lugs & locks). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-02-2004, 04:32 PM   #3
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Anyone else? Just want to make sure I get the correct ones put my rally's on and not have to drive to the parts store 6 times. :p Wanna make sure they are closed end and will go all the way over the studs too. If someone had a pic too. That would be great.
Old 06-02-2004, 06:51 PM   #4
crazy longhorn
As I remember, the studs were about 1 " long.....just be sure to have 1 1/8 - 1 1/4" depth inside the closed end lug nuts ,so you dont bottom out before tightening, & you should do fine. I didnt opt to run the lock nuts with the kit, so I picked up an extra 4 pack of nuts. they will be listed for steel wheels. crazyL
Thread Tools
Display Modes
