Old 06-02-2004, 08:02 PM   #1
kickinasphalt
kickinasphalt's Avatar
HELP! Slack in steering!
Just picked up a 72 4x4 that has slack in the steering. You can have the wheels straight forward and move the steering wheel back and forth from about 11:00 to 2:00 position (maybe 30 degrees or so) without the wheels moving. I also can do the same by just grabing the steering shaft from underneath the inner fender. It must be something in the gear box. Any ideas?
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73
1972 C-10 Longbox,350/350
1998 Pontiac Grand Prix GTP
FOR SALE: 1971 K-10 Longbox,350/SM465/NP205
kickinasphalt is offline   Reply With Quote
Old 06-02-2004, 08:13 PM   #2
cableguy0
sounds like it is probably time for a new gear box with that much slop in it
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-02-2004, 08:39 PM   #3
pickup6772
pickup6772's Avatar
BEFORE YOU PULL EVERYTHING APART, TRY TO ADJUST IT FIRST. IT'S SIMPLE.TAKE A 3/16 ALLEN KEY(PREFFERABLY A SOCKET-TYPE FOR BETTER LEVERAGE), AND A 5/8 BOX WRENCH. MAKE SURE THE WHELLS ARE POINTING STRAIGHT, AND THE WHEEL IS CENTERED BEFORE YOU START. WHILE HOLDING THE ADJUSTING SHAFT WITH THE ALLEN KEYBACK OFF THE LOCKING NUT 1/4 TURN, AND HOLD IT THERE. NOW TIGHTEN THE ADJUSTING SHAFT TILL IT IS JUST SNUG- DO NOT OVER TIGHTEN IT!! NOW BACK OFF THE SHAFT 1/4 TO 1/3 TURN-NO MORE. NOW WHILE HOLDING THE ADJUSTING SHAFT, TIGHTEN THE LOCK-NUT, AND YOU'RE DONE. ALSO CHECK THE REST OF THE FRONT END. IT'S POSSIBLE, THAT IT MIGHT NOT BE THE STEERING BOX AT ALL.
MIKE
'67 C/10 2WD LWB
'89 MERCURY GRAND MARQUIS LS
COUNTRY TILL THE DAY I DIE
pickup6772 is offline   Reply With Quote
Old 06-02-2004, 10:33 PM   #4
franko72
Franko72
franko72's Avatar
tightening the adjusting nut will buy you a little time. It will improve slightly until the bearings fall out and your steering goes out. Learned that one from a bad experience.I didnt over tighten the gear box either.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 06-03-2004, 12:24 AM   #5
chevy71super
Check the box to the frame mounts. The box may be moving on the frame. If you are lucky the bolts will just be loose, if you are unlucky (like me) the frame is either cracked or the bolt holes are rounded it. Common problem with most 4X4's that were "used".
Doug
chevy71super is offline   Reply With Quote
Old 06-03-2004, 01:44 AM   #6
kickinasphalt
I tried adjusting it and it didn't change anything. And no its not mounted loosely or anything. What is inside the box that commonly wears out and creates slack?
Old 06-03-2004, 06:26 AM   #7
JimKshortstep4x4
Smile
Your box has an unusual amount of play in it. Outside of the sector shaft and steer shaft bearings, the gears can wear. I would replace the box.
Jim
Thread Tools
Display Modes
