Old 06-02-2004, 10:41 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
saginaw 4 speed shifter ideas ?
Im in the process of getting the 4 speed saginaw put into my truck but all the after market shifters I can get are too far back and they will hit the seat any one else have any ideas for me
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-02-2004, 10:43 PM   #2
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
I have a saginaw, and yes it was bent really far back, so I heated it with a torch and bent it forward...pretty ghetto, but the shifter boot covers it anyways
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 06-02-2004, 11:09 PM   #3
crazy longhorn
Fabricate till you "puke"
i have also heated & bent, or cut & rewelded shifter handles.....its not ghetto, it "backyard tech" the shifter handle in my longhorn was made from a chunk of 1/2" x 1" flat steel(its not chrome, but works nice). i have heard that guys have used a hurst comp plus shifter for a 57 Belair to fit the bench seat in the truck! i havent tryed it myself, so maybe someone will chime in with details. Best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-02-2004, 11:23 PM   #4
pissonNOS
senior member
pissonNOS's Avatar
well I wanted to "backyard tech" one too but was advised not too, what do you guys think og cutting up and S-10 shifter and welding some flat iron on it so it can bolt to the shifter?
69 GMC bagged
Old 06-02-2004, 11:36 PM   #5
crazy longhorn
If you are a welder, i dont see why not.....i havent had any problems with modified shifter handles. Just grab one that pretty much fits the seat, & weld the flat iron on with 2 holes in it to mount it crazyL
Old 06-02-2004, 11:39 PM   #6
MandarinSixSeven
Seasonal Poster
Just get a shifter boot and all is well...the difference between bending and buying will not be noticeable unless you are taking your truck to some concourse show, then you might lose some points
67 GMC Short Step
Kelowna BC, Canada
Member of DTPW
Old 06-03-2004, 09:33 PM   #7
pissonNOS
senior member
pissonNOS's Avatar
how about some pics of shifters u guys have in ur trucks
69 GMC bagged
Old 06-04-2004, 10:23 AM   #8
crazy longhorn
I do have a couple shots of the shifter, & also the Richmond trans from the top (center hump out of the floor)......but i need to upload them yet. crazyL
Thread Tools
Display Modes
