Old 06-04-2004, 02:26 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Priming and blocking, priming and blocking...
Last weekend it was sand blasting the inside of the truck bed followed by self-etching primer. This weekend its prime and block time for the outside of the bed a couple of more times. I wonder if anybody hates this part of bodywork worse than me. I know its necessary for a great looking paint job but it bores me to tears.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-04-2004, 02:34 PM   #2
chevytruckfan
chevytruckfan's Avatar
Do you block sand after every coat of primer? I was told put about 4 coats on with a contracting mist for a guide then block sand. I help a body shop owner block sand a Diamondt T (Lot of freakin sheet metal) but we only sanded once. I don't know if he did it to prior coats or shot another primer after?
chevytruckfan is offline   Reply With Quote
Old 06-04-2004, 03:02 PM   #3
71RestoRod
71RestoRod's Avatar
Everytime I get into bodywork the wife pokes fun at me... she says "There you go again, put it on, take it off, put it on, take it off. ... ...just paint the darn thing!!!)
71RestoRod is offline   Reply With Quote
Old 06-04-2004, 03:04 PM   #4
Dean
Dean's Avatar
I use high building primer with a guide coat then sand. I usually repeat until I am comfortable with what I see.
Not my favorite job either. The details make the paint job though.
Dean is offline   Reply With Quote
Old 06-04-2004, 03:33 PM   #5
dubie
dubie's Avatar
Body work BLOWS!!! as long as mine looks good from 5 feet away, I'm happy
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-04-2004, 04:22 PM   #6
mocwon
Keep On Truckin'
mocwon's Avatar
Yes, I block after every coat of primer, using 3M guide coat, and use a long board whenever possible. I use 180 until the low spots are all gone and then prime and block with 320, then prime and block with 600, then base coat clear coat it then friggin' sand again starting with 1000 grit all the way up to 1500 or 2000 grit then buffing with three different compounds. I don't do any of the paint work myself, a buddy of mine that owns the shop does that but the rest is my job.
Just Passin' Thru
Old 06-04-2004, 07:27 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I AGREE!!!!!!!!
Old 06-04-2004, 10:19 PM   #8
tphsmith
still buypickupparts
tphsmith's Avatar
3 weeks here for me blocking and sanding, still every day after work, sheesh I thought that maybe Id have the hang of it by now but, I get home from work and still sand and block. Wife gets home shakes her head and says see ya in the morning. She's been realy cool about the whole project
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Thread Tools
Display Modes
