Old 06-08-2004, 03:19 AM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Tranny Question
is it possible to swap a muscle car style 4speed(like a t10) into a 71? the other cab i am using is a setup for a manual.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 06-08-2004, 09:05 AM   #2
crazy longhorn
Fabricate till you "puke"
yes you can I ran an M21 muncie in my 71 (pretty easy swap). Remember that some of the hypo car trannies had a 1 1/8 x 26 spline input shaft, vs 1 1/8 x 10 spline on the truck trans. the centerhole on the bell is also a diff size for the car(4.683, vs 5.126 on the truck). If you use a 67 or older truck bell, you will have the proper bell to swap the car trans in. im not sure on the lenght/spline on the T -10, but the muncie (M 20/21) will bolt right in where a saginaw 3 spd came out (no driveline mods). best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-10-2004, 01:34 AM   #3
Blue85
Oilfield Trash
Blue85's Avatar
what kind of shifter did u use?
87 Chev 3+3 4x4
Old 06-10-2004, 08:41 AM   #4
crazy longhorn
I used a Hurst . the indy, super speedway, or the competion plus should work. the indy & the superspeedway were a more universal fit, & mount the shifter fairly high on the trans (not a problem in the truck). If you have a bench seat, you may have to modify the handle, or build your own to clear the seat(the handle bolts off with 2 bolts). of the 3 listed, the comp plus is the best quality. you could probably run a Ramrod (vertical gate), but would have to "butcher" the floor pretty good to fit it. Best of luck,crazyL
Thread Tools
Display Modes
