Old 06-08-2004, 11:17 PM   #1
krue
Designated A-hole!
krue's Avatar
What a mess!
It's hard to tell from this pic but EVERY wire on my engine harness has been spliced on!
I am still up in the air whether to rewire it myself or buy a harness for it. How hard is it to get the wires out of the fuse box plug?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-09-2004, 06:35 AM   #2
JimKshortstep4x4
Smile
It is a little tricky to get the spades out of the housing, but if you soak them with a penetrant to soften the tar it helps. I use a needle nose pliers to squeeze the spade so as to clear the "hook" on it and then pull the wire out.
If you don't know what the spades look like I can post a pic tonight.
Jim
Old 06-09-2004, 07:11 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
use one of those freebie flat screwdrivers that all the tool guys give out. go in the firewall side of plug & depress tang, then tug wire out.
I recommend buying new harness unless you want to do some changing. like adding HEI or elec. fans etc.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-09-2004, 01:13 PM   #4
ChrisK10
1971 C20 Custom Camper
ChrisK10's Avatar
A friend of mine heard of another company that makes wiring kits. This one is called It's A Snap Wire and Cable, here's the link to one of the kits...
It's A Snap
The ZZ-20 has 20 mini fuses and 21 circuits. The ground wire kit has ground labeled every 4" down wire, GXL flame and oil resistant wire, 100' of 18 gauge wire, and 50' of 14 gauge wire.
Price: $149 for the ZZ-20 wiring kit, and $44 for the ground kit.
Here's the question... how does this compare to other wiring kits like Painless?
'71 Chevy C20 Custom Camper, 454, TH400
'97 GMC K1500 5.7L
ChrisK10 is offline   Reply With Quote
Thread Tools
Display Modes
