Old 04-04-2002, 11:30 AM   #1
halfwaythere
Post setting the doors
I finally got the cab and doors back from the autobody shop and I was wondering if any body knew of any tricks of hanging them. they are on now but don't fit worth a damn. anything would be great.
I was also wondering what is the procedure for installing the door components. Locks Before glass? glass before locks???
I will post pics asap.
everybody just seems jealous!!!
halfwaythere is offline   Reply With Quote
Old 04-04-2002, 12:29 PM   #2
Als454
Post
I would be interested in some tips also. I have mine hung (after walking away and coming back several times)but they need to be aligned. I'm not sure where to start. Would like to know if there is a trick to aligning the doors and also the front clip.
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
3" Exhaust W/Headers
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 04-04-2002, 12:40 PM   #3
ty1295
Post
Aligning body panels is hard to describe with just text, and over a computer.
But I will try.
I usually remove the door stricker/latch. I then adjust the hinges so that the door when closed has an even gap, top bottom, back, etc. This can be adjusted with the bolts that attach hinge to cowl. Trial and error here.
Then adjust top/bottom in and out.. For example top of window may stick out, when rocker of door is flush. Adjust this with the bolts that attach hinge to door.
You then may have to go back to gap thing, and back and forth...
After you get door they way you like, and yes 2 x 4's and bending is acceptable method. Then install the latch, thing to look for is when door closes it doesn't jump up or down when it activates latch. If it does latch needs adjusted up and down. In and out will adjust flush with rear of cab.
Trial and error mostly. Be sure door has hardware installed, as the weight can make difference.
Jeff Scott
'70 GMC Stepside, Short box
'67 Camaro
'63 Nova
'92 GMC typhoon
Jeff Scott
'63 Nova
'92 GMC typhoon
'95 Tahoe
ty1295 is offline   Reply With Quote
Old 04-04-2002, 01:11 PM   #4
Blue_71
Bloo
Blue_71's Avatar
Post
the way me and my freind did it was i held the door in place, left the back latch on and closed the latch, then hekd it the best i could while he bolted. they still work perfect ever after setting cab on frame (did that with cab on blocks)
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 04-04-2002, 02:10 PM   #5
johnnyp
Keepin' It Stock
johnnyp's Avatar
Post
I agree with ty1295, but also make sure you do this with the door seals installed. I spent a lot of time getting mine just right and then installed the seals and the door wouldn't close - duh!
72 Sierra Grande - "Maych"
sierraG on some boards
If a man speaks in the middle of a forest and there is no woman around to hear him, is he still wrong?
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
Maych Home Page
72 Sierra Grande - Maych
johnnyp is offline   Reply With Quote
Thread Tools
Display Modes
