Old 06-19-2004, 09:29 AM   #1
70-K10-292
Question 292 Head
Looking for a good head for my 70 292 reasonable.Where are the casting numbers on these heads? I have looked all over,only place left is under the valve cover?
Where Am I ? How did I get Here ?
1970 K-10 292 Longbed stepside (now a stakerack)powersteering ,Factory step bumper,Tow Hooks,Deluxe gauges Tach & Throttle, 4 speed manual 1 out of 464 made with protectoplate intact .
70-K10-292 is offline   Reply With Quote
Old 06-19-2004, 10:39 PM   #2
Rod
Thats where they are.. under the valve cover. Cast into the head.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-19-2004, 10:42 PM   #3
70-K10-292
I kinda figured thats where theyd be ! Anyone have a head out there?
Old 06-20-2004, 01:12 AM   #4
Lgriffin
I've got one, but I'm on the other coast. You should be able to use any head from a 194, 230, 250. The only problem might be a smaller combustion chamber and higher compression.
Larry
68 C20 327 daily driver
63 C20 292 Camper truck
65 C10 ? Custom Cab AC,PB,PS,$flasher
Lgriffin is offline   Reply With Quote
Old 06-20-2004, 09:01 AM   #5
70-K10-292
Exclamation
They are available still at GM but for $585.00 ! I will try to hold out for a cheaper one !
Old 06-20-2004, 09:10 AM   #6
cdowns
cdowns's Avatar
look thru the classifieds www.inliners.org
Old 06-21-2004, 09:24 AM   #7
MOTHERTRUCKERS
I have 1 that just came off a running 292 150.00 or 1 fresh from the machine shop magnifluxed,pressure tested,new valve job, hot tanked and painted black 450.00.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Thread Tools
Display Modes
