Old 06-21-2004, 01:13 PM   #1
gabet40
will seats from 77 blazer work for ours?
my cousin wrecked her 77 blazer a while back and said we can have the seats out of it. so i was wonderin if anyone knew how well they match up
Current owner of 2016 2500 Silverado Midnight Edition.
Former owner of:
69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4
72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust
gabet40 is offline   Reply With Quote
Old 06-21-2004, 08:02 PM   #2
JimKshortstep4x4
Smile
77 Blazer seats will bolt to the 69-72 seat brackets and they will look good in the 69-72's. The tops of the back part are not as rounded as the 69-72
so there is a minor difference.
The 77 Blazer brackets are too high so they are not a direct bolt in. The 77 Blazer has a flat floor where the brackets bolt up in front, whereas the 69-72 have a raised area.
Jim
Old 06-22-2004, 12:48 PM   #3
gabet40
ok so i just have to pick up a pair of brackets then right? im not sure what happened to ours but they were gone when we got the blazer
Former owner of:
Old 06-23-2004, 05:33 PM   #4
npbra
Stock brackets from the 77 will work with modification. You will need to cut them down and re-weld them to the right height. I did it with the buckets out of my 80 Jimmy when I put them in my 72 Jimmy 2X2. Most of the holes line up on the driver's side, but on the passenger side it becomes a whole nother game. 77 bracket won't work without serious reworking. I used a second drivers seat bracket and have the seat mounted so it will not fold forward. Don't have a back seat, so didn't need access through the front. Easisest way to do the swap is with original brackets out of the truck, but they are hard to find.
npbra is offline   Reply With Quote
Old 06-25-2004, 08:19 AM   #5
Huck
Huck's Avatar
The 73 and up buckets look almost identical to the 69-72 buckets---however if you ever want to recover the seat covers----you need to check real careful as soom we recently pulled were not the same size----with a ruller, if you were to check the seat height (foam) from the top where you tush goes to the bottom where the seatcover wraps around, it was at least 1" smaller on the later model seats. This may be unique to truck buckets but -----I would check the measurement before I would buy replacement seat covers.
The mounting brackets are very different but can be modified ow swapped around pretty easy.
Huck is offline   Reply With Quote
Thread Tools
Display Modes
