Old 07-02-2004, 12:36 PM   #1
monster88
85 K5 blazer - exhaust gasket
i need to change the gasket on my exhaust...any tips or tricks that might make this a bit easier?
85 Blazer K5, 350- 4bbl 3:73 gears, 3 in sus. lift, 2 in body lift, 35's
"While the Wicked stand confounded, call me with thy Saints surrounded"
"Why dont you just sit there and bleed awhile, before you taste some real pain"
monster88 is offline   Reply With Quote
Old 12-25-2004, 04:10 AM   #2
blaserman
blaserman's Avatar
Exclamation Exhaust Gasket
NO REALLY EASY WAY TO DO IT. WHEN I REDID MINE I DID ONE SIDE AT A TIME. I UNKOOKED MY HEADERS FROM THE PIPE AND JUST TOOK THE BOLTS OUT THEN PUT THE GASKET IN USING ONE BOLT ON EACH END TO KEEP IT IN PLACE. BUT I GUESS THE MAIN DIFFERENCE IS THAT I DO NOT HAVE ANY EMMISIONS ON MY 86 BLAZER. I GET A EXSEMPTION EVERY TWO YEARS FOR IT.
blaserman is offline   Reply With Quote
Old 02-18-2005, 03:39 PM   #3
mxfireman
mxfireman's Avatar
It's a PIA no matter how you do it....
Shane
***WANTED*** Medium Blue Door Panels, 4" Shackle Flip, Sway Bar Disconnects
***FOR SALE*** SPAL 16" Electric Fan, Factory A/C Parts
mxfireman is offline   Reply With Quote
Old 02-18-2005, 06:40 PM   #4
kevinr1970
On my '86 GMC I had to replace both manifold gaskets and the doughnut gaskets. If you are replacing the do-nut gaskets, keep in mind there will probably still be a metal ring tucked up in the manifold. I learned this the hard way when I couldn't get the new gasket to seat right. When I did the other one, the ring practicaly fell out so I knew what was wrong with the first one, but it didn't leak so I hoped it would work. It did..... for about 2 days.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Thread Tools
Display Modes
