Old 07-02-2004, 03:49 PM   #1
mark460
Hydraulic Winch
Does anyone know how to hook up a hydraulic winch to the power steering pump?
Mark
mark460 is offline   Reply With Quote
Old 07-10-2004, 02:42 PM   #2
frost89434
frost89434's Avatar
Is it a milemarker winch? I install these winches at work.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 07-13-2004, 12:36 PM   #3
mark460
It is a Ramsey winch, but it probably similar to the milemarker in that it has an inlet and an outlet for the hydraulic lines. Is it just tied into the power steering lines with "T" fittings, or something?
THanks
Mark
Old 07-13-2004, 12:47 PM   #4
frost89434
frost89434's Avatar
On the milemarker winches you only use the pressure line. You take the pressure from the pump into the winch. Then the out side of the winch goes into the gear box. It makes a loop is what it does. I hope this helps. JIM
Sparks, Nevada
Thread Tools
Display Modes
