Old 07-06-2004, 09:53 PM   #1
project87
Tire & wheel question
1987 1/2 ton
I'm ordering a lift and some wheels/tires. i'm not going high, just enough to fit 33x12.5's
2" lift? i was told that this would be enough to fit them.
also, 15x10 wheels with 3-3/4" backspacing is what i'm looking at. Anyone have the same setup? looking for pictures of how the turnout might be. thanks!
project87 is offline   Reply With Quote
Old 07-06-2004, 10:01 PM   #2
1FaastC10
1FaastC10's Avatar
4" would probably be best with such a wide deep wheel. why not go 15x8?
1FaastC10 is offline   Reply With Quote
Old 07-07-2004, 04:47 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
On my 70 the wheels are the same back spacing, tires are 35" BFGs and the lift is a 2" HD tuff country(about 3.5" net lift). The tires rub when turning w/ springs flexed. Pics in link in signature. The 33" TSLs did not rub. (the 70 is the white one)
Just noticed you have an 87, you will definetly have no problem w/ 33s and 2" lift. I ran this set-up on an 85 w/ only 1.5" of lift and the tires never rubbed. You could probably run 33s on 8" wide rims w/ no lift.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-07-2004, 07:43 PM   #4
project87
With such a wide tire, and only an 8" wheel. The tread center is pushed outward (have you ever stepped on a tire that isn't mounted to a rim, it pushed the center of the tread out.) I'd like to keep the tread profile as flat as possible... I noticed the backspacing of almost all the aftermarket wheels are the same between 15x8 and 15x10 wheels. so basically the extra 2 inches would be out right? moving the center of the tread over about 1"? thanks!
Thread Tools
Display Modes
