Old 07-13-2004, 11:30 PM   #1
Cethern
What was I thinking??
Cethern's Avatar
A question or two
Ok when I got this K5 the temp guage didn't work so I got a new sending unit and added a new wire from the one I think was the right one. and went to see how hot I was getting and the darn thing just pegged it self like it was grounded some how.
The best I can think of is the guage is bad. any ideas?
Next question is about the darn door on the drivers side is a ***** to close or open and it doesn't really close all the way. it look like everything lines up ok. could it be a bad door thingy. I'm about ready to stop by a body shop and ask them to look at it lol. I'm killing the door with my Shoulder and not really do that much good either.
Thanks for any ideas Guys and Gals.
Cethern
From these pic's you can see the temp unit and which wire I hooked back up from the book it looked to be the right one.
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
Old 07-14-2004, 05:00 AM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I HAVE NO IDEA ABOUT THE TEMP THING, SORRY
U SAID UR DOOR APPEARS 2 LINE UP BUT IS HARD 2 OPEN AND CLOSE
WATCH UR WINDSHEILD FRAME WHEN IT OPENS, IF IT MOVES WHEN U
OPEN UR DOOR IT IS STRUCTURAL, (ROCKER BOXES, CAB FLOOR, ETC.)
IF YOUR WINDSHEILD FRAME DOES NOT MOVE IT IS PROBABLY IN THE
HINGES ON THE DOOR OR BODY THEMSELVES, PM GEE_EMM (EXPERT )
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-14-2004, 09:30 AM   #3
Cethern
Cethern's Avatar
When I get back home I'll spend more time looking at the darn thing.
Thanks for the imput
Cethern
Old 07-14-2004, 11:36 AM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Also, check your body mounts. The doors can be hard to close if the body mounts are shot.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-14-2004, 12:12 PM   #5
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
The temp guage works the other way. If the connection is open, then it will peg out. If it is shorted to ground it will drop to zero. So do a continuity check on the wire coming from the sender to the wiring block, then from the block to the dash harness. Do you have the wiring diagram? There is one on the FAQ section of the board. It will help you trace the wiring. That should be your only problem. If the guage itself was bad, it would never move. Let us know how it turns out, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 07-14-2004, 12:13 PM   #6
smokekiki
Mike
smokekiki's Avatar
For the temp gauge,make sure Your grounds are in place.There is a ground from the panel to the dash.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 07-14-2004, 03:25 PM   #7
Cethern
Cethern's Avatar
When I got the truck the gauge was all most where it is now it only moved after I did what I did... I'll check everything again I'm sure I have the right green wire but I could be wrong it has happend before lol.
Smokekiki.. The ground behind the dash is something I need to look at I'm sure whom ever had the truck painted had the dash out and could of messed something up.
Thanks for the idea On the body mounts Bouncy I want new ones anyway.
Cethern
Old 07-19-2004, 05:02 PM   #8
mister.freeze
mister.freeze's Avatar
Temp senders come in different resistance ranges. I overheated once and melted one, and had the same problem whenI replaced it. Go get another one and try it. I don't know if there are different pn's or what. Check the ohm resistance and cross that at the auto parts store. Your wiring is probable OK.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 07-22-2004, 09:46 PM   #9
Cethern
Cethern's Avatar
I guess I'll try another one just for the fun of it. then I'll get a new guage if that doesn't work.
thanks all the imput guys
Cethern
Old 07-22-2004, 10:04 PM   #10
1970blazin
Blazerless:-(
1970blazin's Avatar
Where is this ground wire that everyone talks about for the dash cluster?? I need to check mine cause my temp guage and fuel guage and dash lights aren't working...Thanks!
Diane
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 07-22-2004, 10:09 PM   #11
Cethern
Cethern's Avatar
I'm not to sure of that myself. I'm guessing you have made sure the plug is in good?
Ceth
Old 07-22-2004, 10:27 PM   #12
skid
Make sure your sending unit is for a gauge, not a warning light. The warning light sending units will peg the gauges.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 07-22-2004, 11:05 PM   #13
Cethern
Cethern's Avatar
Well it pegged the gauge the first time I turned the key.....I know I told that goof I had Gauges.
thanks Skid
Ceth
Thread Tools
Display Modes
