07-14-2004, 06:15 PM | #1 |
It followed me home?
4:10's and a 26" tire?
So I have decided to swap out my 3:73 with 4:10's that I have had laying around before I go to the track next weekend. Do you think that is too much gear for a 26" tire and a 700r? I am not concerned about rpm on highway, I just want this truck to scream light to light. I would like to dip into the 14's and ran a 15:4 with the 3:73s. I hope the new shift kit and gears will allow me to drop a few tenths. So am I going to get 0% traction at the light? or not much different than now?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
07-14-2004, 06:42 PM | #2 |
Garage Queen Material
you only ran a 15.4 with a zz4 engine????
07-14-2004, 06:48 PM | #3 | |
1. Power robbing mile high air 2. Hot 96 degrees 3. I need some more carb
07-14-2004, 06:52 PM | #4 |
hmm.... well that makes it a little better
i was gonna say because i ran a 15.7 with 2.73's AND my timing advanced about 45 degrees |
07-14-2004, 07:37 PM | #5 |
if you haven't done anything to increase traction from the last iem you went then you will probly go slower with the 4:10's. torque multiplication dosen't do much for you if its just going up in tire smoke. some drag radials or et streets and some traction bars would help alot
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
07-15-2004, 08:37 AM | #6 | |
So, I am going to 4.10's soon, would like 4.33's but cannot get that in a 10 bolt setup. I think you are about right with 4.10 and 26" tires, but you can go to Prestage.com and plug in tire size, etc. and see your RPM at certain speeds. You will want to be a few hundred RPM's short of redline for the best run IMHO, being in third gear @ a 1 to 1 ratio.
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL. |
07-15-2004, 10:30 AM | #7 | ||
07-15-2004, 06:47 PM | #8 |
driving is in my blood
4.10's and a 700r4's 3. somthing first equal no traction without some slicks. But if you keep the wheelspin down then they could help make up for it threw the rest of the 1/4.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
07-15-2004, 08:29 PM | #9 |
Honestly, 3.73's/26" Tire/700R4 sould be the PERFECT combo. Traction is 100% necessary to run good times. If you can get a 2.0 60' (or even better than that) you'll get some good times, trust me. Just remember, every .1 off your 60', is worth .2 at the big end.
07-16-2004, 08:04 AM | #10 | |
07-16-2004, 08:42 AM | #11 | |
That is exactly why I wanted to switch them, the truck is great off the light but just doesnt have enough through the traps. My mechanic is only charging me $50 to swap so if they dont work I can always switch them back and not be out a lot of money.
07-16-2004, 09:08 AM | #12 | |
My moto is ............ If it blows up, just go with more HP & Gear !!
07-16-2004, 11:00 AM | #13 |
So what psi should I have my tires?
07-16-2004, 12:00 PM | #14 |
what kind of tires are they?
07-16-2004, 12:02 PM | #15 |
I was at the track last night and I'm running a 28X12 slicks with a 3.42 gear. It's all about traction PERIOD! These trucks do not need more than a 3.73 unless you have a 31-33" slick. The problem unfortunatley is no weight transfer to the rear leafs. If you put such a low gear in your truck you will hate driving on the street. I would put your money into the motor or four link the rear. I have many friends that have gone overboard modifying their rides to get good track times, but now they don't drive them on the street. I would rather have a high horsepower motor and feather it outta the hole than have a low gear and a high reving engine when cruising. It just depends how much time you spend at the track. I have gone with a 650hp motor and have the stock 10 bolt. I run consistent 12.50's and think there's another second to lose with a four link. I will never give up the 3.42's.
Please post times whenever you get back from the track. Oh by the way, I used to have a 383/450hp sbc and same rear and ran 14.2's, so bring on the power.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
07-16-2004, 12:12 PM | #16 | |
Bfg comp ta 295-35-18
07-16-2004, 12:39 PM | #17 | |
Short of a mountain motor like yours, and that must be a very cool site, most of us will need more rear gear & a higher stall converter to get the weight of the truck moving. So, we need a torque multiplier to get close to your torque effect with your mild rear gears.
07-16-2004, 12:51 PM | #18 |
My goal is to run a low/mid 14 with my current setup. I'm pretty sure I can do it. But Cochino, don't forget NHRA Correction Factor. Where you're at, if you can run a 14, that's nearly like running a 12 at sea level. So, if you brought your truck HERE and raced it, you'd be impressed.
Here's the site for the correction ~> NHRA Correction Page |
07-16-2004, 12:52 PM | #19 |
all righty heres a table i formed with a 700R4 in OD and a 26 inch tall tire going 70 mph
3.42-2167.6197942185204 rpm 3.88-2459.1709946104847 rpm 4.11-2604.9465948064676 rpm 4.56-2890.1597256246937 rpm now at 80 3.42-2477.279764821166 rpm 3.88-2810.481136697697 rpm 4.11-2977.0818226359624 rpm 4.56-3303.039686428221 rpm now at 90 3.42-2786.9397354238117 rpm 3.88-3161.791278784909 rpm 4.11-3349.217050465458 rpm 4.56-3715.9196472317485 rpm if you ask me, i wouldn't mind running a 4.56 on the street as the fastest i would ever be going would be 80 at 3303 rpm, now this is with the 700R4s .7:1 over drive and not with a turbo 350 or 400 1:1 3rd gear. i used the calculator here http://www.race-cars.net/calculators...alculator.html if y'all have any questions.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
07-16-2004, 01:22 PM | #20 | |
07-16-2004, 08:46 PM | #21 | |
Thread Tools | |
Display Modes | |
