Old 07-16-2004, 11:22 AM   #1
68jimmy
68jimmy's Avatar
Brake pedal slowly goes to floor??
Hello All,
My 68 GMC 3/4t came equipped with power assisted drum brakes on all 4 corners. I've noticed that when I'm sitting at a stop light or such that the brake pedal ever so slightly is going to the floor. What causes this? A leak in the wheel cylinders or something to do with the power assist unit itself?
thanks!
68jimmy is offline   Reply With Quote
Old 07-16-2004, 02:11 PM   #2
ed455
Captain Ed
Could be:
A) Leaking wheel cylinder which will be obvious by looking under the vehicle to see if fluid is leaking out from inside the drum. It will also be noticable by a pretty severe loss of brake fluid in the master cylinder resevoir. If it turns out to be a wheel cylinder, it will require a full rear brake job as the shoes will be fluid soaked and effectively ruined.
B) A bad master cylinder that is letting fluid bypass internally. It often leaks at the back of the master cylinder. If the brake booster is wet and the paint is peeling on the bottom of the brake booster (if it's painted), then this is the culprit. If there is no sign of a leak anywhere, then the master cylinder is the culprit in this situation as well. Master cylinders are cheap at around $25-$30 for most of OUR application.
My vote is for "B" because while wheel cylinder failure is very common, a failure that would cause an obviously dropping pedal is not common. There are other things that could cause your problem as well, but these are the most likely scenarios,
ed455 is offline   Reply With Quote
Old 07-16-2004, 03:44 PM   #3
68jimmy
68jimmy's Avatar
I haven't noticed any loss of fluid in the master cylinder, nor any wet spots or runs on any of the wheels. I'll pick up a new ms and see if that cures it...
thanks!
Old 07-16-2004, 03:51 PM   #4
ed455
Captain Ed
Don't forget to bench-bleed it.
Old 07-24-2004, 10:33 PM   #5
roccon31
try adjusting your rear brakes...if your rear drum brakes are out of adjustment, your pedal will drift down slowly after you apply the brakes.
roccon31 is offline   Reply With Quote
Old 08-02-2004, 09:54 PM   #6
flatblackclassic
I have this problem on my 97 but have not yet got around to adjusting the rear drums. I think I'm just going to upgrade to a rear disc setup.
flatblackclassic is offline   Reply With Quote
Old 08-05-2004, 12:26 AM   #7
K Dubb
www.Dubbmotorsports.com
K Dubb's Avatar
air in the break lines will make it slowy creep to the floor
K Dubb is offline   Reply With Quote
Old 08-05-2004, 06:52 PM   #8
68jimmy
68jimmy's Avatar
I will be doing a rear-end swap here in the next week, so I'll have a chance to re-bleed those again...
Thread Tools
Display Modes
