Old 04-04-2002, 03:55 PM   #1
dubie
dubie's Avatar
Post Who here is running a 350ci with a 3 in the tree??
I am going to swap out the inline for the mighty 350 that most of the guys here are running. How does a 350 run when it's backed by a 3 speed? Will the 3 speed be good enough if I am not planning on using it for a lot of highway travelling? Do I have to replace the rad to supply more coolant to the bigger engine?? If I add headers to this 350, will the shift linkage for the column shift be in the way? sorry bout all the questions, i just want to know everything there is, before I do the engine swap. Please help!! Thanks again
72 C/10 LWB 2wd
250 inline 6, 3 speed column shift. Soon to have a total facelift.
[This message has been edited by dubie (edited April 04, 2002).]
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-04-2002, 04:10 PM   #2
brennecke
brennecke's Avatar
Post
I got one. The headers will have to be the right ones to fit. Some headers will say not for use with column shift vehicles. As for driveability, it does great. Sometimes intown driving is a pain, but that's to be expected.
Never tire of doing what is right II Thess. 3:13
Northeast Missouri
71 LWB original 350 3/speed
Soon to be 500
brennecke is offline   Reply With Quote
Old 04-04-2002, 05:11 PM   #3
REPO1
Shortbox wanna-be.
REPO1's Avatar
Post
When I was 16 I had a '67 with a V8 283 witht the 3 speed. It was fun.
Sylvan Lake, Alberta, Canada
1970 Chevy C20 Custom Camper
#s matching 402BB Turbo 400 trans.
Air conditioning, power steering, manual brakes.
73,600 Original Miles!!
(Add on 2000 more from raod trip!)
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 04-04-2002, 05:11 PM   #4
Benrs86
Benrs86's Avatar
Post
i like mine, but my dad has a friend that might have a 4speed for me so if i can i am going that route. the only thing i dont liek really is the column shift. gets bound up in first so i cant get out of 1st a lot. good luck with it, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 04-04-2002, 05:57 PM   #5
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Post
That is what I am running. But hopefully to change to a Richmond Gear ROD 6 speed tranny.
67
Ben
67Fleetsidedream is offline   Reply With Quote
Old 04-04-2002, 07:04 PM   #6
SCOTI
SCOTI's Avatar
Post
If the motor is making any torque don't try burnouts or second gear scratches 'cause I've broken 2 input shafts that way. As long as you don't lean on them, the tranny will last.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-04-2002, 07:35 PM   #7
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
Mine came stock from the factory with a 350/3-on-the-tree. Everyone hated it from day two...possibly why my grandpa was so eager to give a 3 year old truck to his daughter when she went to college.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-04-2002, 08:10 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
As for the radiator, if yours is in good shape, and everything is good, you should have no problem. If your radiaror is crappy....you'll know on your test drive.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-05-2002, 05:43 AM   #9
Firearmfiend
Post
the short-bed is factory 307 w/ 3-speed and now has a 350... I've put 80K miles on that truck myself and I've hardly had any problems with the set-up... make sure though that when you shift from 1st to 2nd you be careful because the linkage can bind on the column... hard to explain without pics.
as for cooling, grandpa ordered the truck with HD radiator so I've never had overheating problems... maybe one of these days I should post a pic with the options plate, it's kinda neat to look at.
'70 C-10 Short/Fleet 350 (in the family since new)
'70 C-10 Long/Fleet 307 (the Death Machine because it seems like it'll kill you to drive in it)
'70 C-10 Short/Fleet 350 In the family since new and more than 300K on the odometer!
Firearmfiend is offline   Reply With Quote
Old 04-05-2002, 08:57 AM   #10
dubie
dubie's Avatar
Post
I think damn near every 3 in the tree binds when shifting from 1st-2nd. Mine does it all the time. I have a floor shift conversion kit for the 3 speed, so I might go with that for now. Thanks for the info guys
72 C/10 LWB 2wd
Old 04-05-2002, 09:07 AM   #11
okietruck
Post
I just did the I6 to V8 swap in January, using V8 mounts. I'm still runing the saginaw 3 speed with a floor shift. It does just fine with a 3.73 rear end, just feels like it needs another gear when I get over 65. I had to rebuild my radiator last summer so I went with a 3-core and have no overheating problems, I would think the original 2-core may be a little small. My problem with headers was the clutch linkage. Check the footnotes carefully on what headers to use, I went with Heddman 69092. Good luck, the extra power is great.
'72 LWB Stepside
okietruck is offline   Reply With Quote
Thread Tools
Display Modes
