Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 07-19-2004, 10:41 PM   #1
cochran63
cochran63's Avatar
Factory headers and dual exhaust
I bought an 86 chevy 3/4 ton for parts and it has an exhaust like ive never seen before. It has some manifolds that look like headers and a factory dual exhaust. Is this junk or is it worth anything?
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 07-20-2004, 12:10 AM   #2
87Silvy
87Silvy's Avatar
Can ya post some pics?
1987 Chevrolet Silverado
2005 Chevrolet Silverado
87Silvy is offline   Reply With Quote
Old 07-20-2004, 12:16 AM   #3
Russell
Professional Grade
Russell's Avatar
I'd say any dual exhaust is better than single exhaust... Might wanna just pick it up to sell it if it is fairly cheap...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 07-20-2004, 03:14 AM   #4
fine69
fine69's Avatar
My 85 Chevy C30 towtruck has factory headers. They work well. I would snag them up and use them.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 07-20-2004, 07:58 PM   #5
Tom
driving is in my blood
Tom's Avatar
a pic would help, I've never seen or heard of factory headers before.
Old 07-20-2004, 11:17 PM   #6
stan79chevy
stan79chevy's Avatar
i wanna see too
i would think they would have done that back in the muscle car era
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 07-20-2004, 11:34 PM   #7
73 C-20 LWB
Buffalo Elk
73 C-20 LWB's Avatar
I'd sure like to see those. The only factory headers I ahve ever seen were on pre 1973 cars...never seen any on a truck.
Kelly C. Hanna
Hanna Woodworks
73 C-20 LWB is offline   Reply With Quote
Old 07-20-2004, 11:42 PM   #8
1972C10
1972C10's Avatar
Ive got a pair on my 85 C20 It had came with a 454 with steel tube manifold headers but i swapped over to a 350 and managed to score a set of headers that even bolted up to the big block exhaust
My truck is a scottsdale and it has factory duals and heat sheilds over the pipes for the entire length to the mufflers its like someone bent a 2 1/2 pipe then bent a 3 just like it sawwed it in half and welded it over it.. Mines stainless and the best exhaust ive ever had. only bad thing is it uses a 15 dollar donut gasket.
1972C10 is offline   Reply With Quote
Old 07-21-2004, 08:13 AM   #9
Beyond
I think I've seen a burb with those headers on it. California emissions setup with 2 air pumps and lots of hoses. Did the ones you looked at have an expansion bellows between the 2 front and rear tubes?
1972 C10 Daily Driver Project Truck
1971 Nova 9 second Tire Fryer
1988 Burb
1987 454 Dually Crew Cab
Beyond is offline   Reply With Quote
Old 07-21-2004, 10:07 PM   #10
cochran63
cochran63's Avatar
Factory headers
I already own the exhaust. It sounds like the same exhaust mentioned by 1972c10. bost sides have a tube coming from each pipe going into a black canister that would have been mounted on either side of the carb. I will get some pics as soon as possible. does this setup have any value, as i do not need them.
Old 07-22-2004, 05:47 PM   #11
GMC1tondually4dr
GM made stainless steel exhaust for motor homes and other trucks that generated a lot of exhaust heat. They kind of look like headers.
If youv'e got 'em keep 'em!! When they are cool, see if a magnet sticks to them. It won't stick to SS.
If they crack they can be welded and fixed, unlike cast iron exhaust. (yea, I know you can weld cast iron, but it's a B---H!).
454's under load (like towing and being a motorhome) generate a lot of heat.
Just my .02
CCDually
GMC1tondually4dr is offline   Reply With Quote
Old 07-22-2004, 06:48 PM   #12
1972C10
1972C10's Avatar
Yeah Scottsdale type equip I like mine I had the 454 version but changed to sbc and i managed to pick up a set Belive it or not my whole exhaust is cat convertor free and stainless. At least to the muffs
I welded the A.I.R. Holes up that was my only complaint you cant buy a plug to fit them like you can with older cast manifolds I took electric box knockouts and ground them down a little to make them fit and welded them over the holes Its a metric flare nut
On my big block i has just sqeezed the tubes shut and welded them Here is a pic of mine installed
http://mysite.verizon.net/res6o8ny/p...ture%20017.jpg
Old 07-23-2004, 06:47 PM   #13
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
no picture
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-23-2004, 08:24 PM   #14
1972C10
1972C10's Avatar
Old 07-23-2004, 08:36 PM   #15
MylilBowTie
Right turn Clyde
Thanks for the pic, the website wasnt working properly for some reason.
Thread Tools
Display Modes
