Old 07-24-2004, 10:16 AM   #1
pierce
pierce's Avatar
NP205 Rebuild 101
I have some slop and vibration from the transfer case and was looking for info about rebuilding it. Has anyone done this? Is there a good manual? Parts available? I can rotate the new driveshaft w new ujoints back and forth about a quarter turn. Is this normal? This will be a first...I redid the rearend with richmond gears and set the pinion depth and backlash to spec and it helped the clunking sound when stopping and starting alot. Gears were badly worn so I'm expecting the tranfer case to be just as worn out.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 07-24-2004, 11:34 AM   #2
skid
This might help you rebuild it...http://bulldogs-house.com/Projects/np205/
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 07-24-2004, 01:08 PM   #3
teamharvey
teamharvey's Avatar
Excellant info !
teamharvey is offline   Reply With Quote
Old 07-24-2004, 01:32 PM   #4
Jimmy72custom
Jimmy72custom's Avatar
Be sure to check the spline coupling that connects the trans to the transfer case. Also trans output shaft spline, and transfer input shaft spline. You may fine allot of wear on the coupling.
Jimmy72custom is offline   Reply With Quote
Old 07-25-2004, 09:37 AM   #5
pierce
pierce's Avatar
Thanks alot for that link skid...nice documentation.
Jimmy72Custom Thanks for the heads up on the splines too.
37 Chevy Coupe
Thread Tools
Display Modes
