Old 07-25-2004, 10:40 PM   #1
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
2WD Blazer suspension pics....
Anyone got them??? Did they have coil spring rears or leafs?? If they are coils, are the trailing arms shorter than truck trailing arms?? I have locater a 4WD frame and will convert the new frame to 2WD drive and then simply swap the body onto the 2WD frame. Later, FCG
FuelCellGuy is offline   Reply With Quote
Old 07-25-2004, 11:15 PM   #2
FuelCellGuy
FUEL CELL GURU
These were posted here before. This will give most an idea of what I am going for......
Old 07-25-2004, 11:18 PM   #3
cdowns
cdowns's Avatar
i don't have pictures but the suspension uses the same trailing arms and coil springs as pickups and the same front suspension as 2wd trucks
Old 07-25-2004, 11:20 PM   #4
grnddwn
belly dragger
grnddwn's Avatar
Truck trailing arms will work
grnddwn is offline   Reply With Quote
Old 07-26-2004, 08:04 AM   #5
Blue Beard
Blue Beard's Avatar
Didn't mention what year....I have two 77 2wd blazers sitting here, both with leaf springs.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 07-26-2004, 11:35 PM   #6
brad2
This is a 2wd frame. May not be much help with all the stuff piled on it.
74 swb
71 2wd Jimmy
82 2wd Blazer
brad2 is offline   Reply With Quote
Old 08-02-2004, 05:40 PM   #7
Grim Reaper
A REAL 2wd 69-72 Blazer will be trailing arms with coils. 4x4 were leaf.
in 73 and up everything went leaf. funny thing is its the same spring for 2wd as 4wd just different spring mounts.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-03-2004, 12:14 AM   #8
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Maybe these will help...I saw this at the Texas Heatwave and poured over it for probably 20 minutes! The guy said it was a 72.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 08-03-2004, 12:27 AM   #9
soala70
soala70's Avatar
what kind of headres? Isnt that a BB?
bogey5
soala70 is offline   Reply With Quote
Old 08-03-2004, 12:28 AM   #10
soala70
soala70's Avatar
sorry on spelling headers
bogey5
Old 08-03-2004, 12:34 AM   #11
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Yeah, that's a big block in there. I didn't ask what brand of headers they were, but the guy said that he would be swapping them for "shorty' Chevelle headers (for ground clearance).
Old 08-03-2004, 12:54 AM   #12
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Also, notice the trick stainless steel alignment spacers on the upper A-arms. I thought that was pretty slick.
Old 08-04-2004, 12:11 AM   #13
soala70
soala70's Avatar
what would be the reason for the spacers?
bogey5
Old 08-04-2004, 01:22 AM   #14
Alexis
Member since 2000
Alexis's Avatar
all O.E. 70-72 2wd blazer were coil spring. Check out the link in my sig. i got some photos of my frame.
Alexis is offline   Reply With Quote
Old 08-10-2004, 12:19 PM   #15
Grim Reaper
All GM's have shims there. That's how you adjust the Camber of the wheel. Camber shims are UGGGGGGLYYYYYYYY. What they will have to do is once the truck is assembled they need to decide a "Normal" ride hight and then get it allignend with shims. Once aligned with the shims then they can measure the shim thickness and cut those spacers to that measurment. Then replace the shims with the spacers to clean it up.
Grim-Reaper
Old 08-10-2004, 03:30 PM   #16
Sublvr72
Sublvr72's Avatar
ok, let me start by saying this, the frame on a 2WD and a 4WD is differant. The 2wd frame curves in where it crosses with the trailing arm where the 4wd frame is straight where it bolts up to leaf springs. a 2wd swap using factory trailing arms is not possible! you would have to swap frames with a 2wd blazer or jimmy or cut and shorten a pickup frame. or lower it with leaf springs and shackles, or do a custom 2, 3 or 4 link in the back. Other than that the front suspension needs to be swapped with a 2wd crossmember and all the stock suspension should just bolt up to that.
grim reaper is dead on the shims. Those shims on the guys upper control arms are to correct the negitave camber you get when you lower or bag a truck. I have never seen shims like those before and they are pretty sick looking. I might look into fabing a set for my burb.
Sublvr72 is offline   Reply With Quote
Old 08-10-2004, 08:12 PM   #17
360hp350
360hp350's Avatar
They look like ceramic coated heddmans.
72 Chevy Chevelle - Firing off saturday morning
74 Chevy Blazer - 360 horsepower 350
78 Chevy Suburban - 454/TH400 parts truck for chevelle
88 Chevy S-Blazer - 2WD, no motor/trans FOR SALE $450
I will turn 19 in boot camp
360hp350 is offline   Reply With Quote
Old 08-10-2004, 11:33 PM   #18
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, I posted a thread asking that exact question and another board member blew the picture up real big. It says Hedman on the tag.
They are very nice and look to fit much better than the Hookers I had for my big block truck.
Old 08-13-2004, 11:02 PM   #19
grnddwn
belly dragger
grnddwn's Avatar
The shims on there are way to big. they look cool but won't work
Old 08-14-2004, 09:15 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah but like Grim Reaper said they will work until he get it aligned. That's the same method we are going to use for my 82 Blazer with a Scotts IFS in it. They send you a stack of washers to set the camber with We decided to get the alignement correct using the washer then machine an adjustable spacer to replace the ugly stack of washers....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-16-2004, 02:51 AM   #21
baggd67
on the pics that mr.shelly posted of the frame, is that a pretty good setup for a 67 sb, and can u lay fram in the back like that if maybe i had a notch, let me know please, going to be installing them pretty soon and i really want to lay frame, thanx guys
baggd67 is offline   Reply With Quote
Thread Tools
Display Modes
