08-01-2004, 08:46 PM | #1 |
battery on the frame
I am thinking of mounting my battery on the drivers side frame below the box. The only thing is that I will use the truck for daily driving. Could this be a problem. Any ideas to design a box that will drop down and out incase it kneed to be jumped. Thanks to all you chevy guys.
08-01-2004, 09:10 PM | #2 |
I am a Referee of life.
The street rod guys have a set-up to do this.I don't know who makes it but you should be able to find it in StreetRodder mag.It tucks up under the body next to the frame and swings down for acess.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
08-01-2004, 09:18 PM | #3 |
there's all sorts of mounting boxes available and as far as emergancy jump starting they sell remote mount kits where you can have terminals whereever you want , in the engine compartment,in a wheelwell,in back of a liscence plate,under a seat ,glovebox,roof etcetc
08-01-2004, 10:03 PM | #4 |
The LuvShack Garage
Just By A Optima Battery And Mount It Upside Down.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-02-2004, 10:43 AM | #5 |
I made a box to hang off the frame on my Dads 70 CST, its mounts just before the rear wheels on the passenger side. I even had louvers punched in some sheet metal for the side walls of the box. Moroso makes remote terminals and I out those on the firewall where the battery box would be. I would take some pictures but the frame is kinda buried in crap right now.
08-02-2004, 10:56 AM | #6 |
nwautofab.com makes the box that you are talking about.
08-20-2004, 07:10 PM | #7 |
08-20-2004, 07:25 PM | #8 |
The LuvShack Garage
Hmmm, Now It Is A Toss Up, Mount A Optima Upside Down With No
Battery Box Thingamagiggy $139.99, Or Buy This For $99.99 And A Walmart Battery For $39.99 And Spend About The Same Amount. ( I GUESS OPTION 2 WOULD BE ALOT SAFER THAN OPTION 1 )
08-20-2004, 10:14 PM | #9 |
Check out the chevy diesel vans, the second battery was on the frame [under the drivers seat I believe]
08-20-2004, 10:53 PM | #10 |
Fabricate till you "puke"
I have a summit battery relocation kit, mounted to the outside of the rail (pass side). i havent had the need to jump start the truck, but have charged it off the fender mounted junction block(same spot i hook the timing lite). the kit was about 40-45 bones, & a little fab work for the tray.....remember, you cant run too many ground straps on that swap. Best of luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-20-2004, 11:19 PM | #11 |
Why don't you mount a second in the engine compartment? I fabricated a battery holder on the left side of the radiator. No luck uploading the pic's. I'll try tomarrow.
Thread Tools | |
Display Modes | |
