Old 08-02-2004, 08:25 PM   #1
GMCGRANDS
U-bolt size on lower control arm shafts ?
I ordered some replacement u-bolts for the lower control arm shafts on my 72 GMC. When I recieved them they were 7/16" dia. The orginal ones are 1/2" ? Anyone else run into this? I checked the shafts they are the same. The spread of the ubolts is the same, just the diameter is different and the holes in the crossmember are different when compared to another crossmember I have. I think I remember Phantom Dually having a problem like this one time.
Mark
72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction
05' GMC Sierra Denali LQ9
GMCGRANDS is offline   Reply With Quote
Old 08-02-2004, 10:15 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
I am in the same situation right now. Stock is 1/2 inch. I was told buy a gm parts man, (30 plus years at the same dealership) that they changed to 9/16" in '73, due to the 1/2" ones breaking. He remembers the bulletin on it from back then. I ordered the 9/16" cause that was all that is still available. $3.87 each my cost. I can get you a part number if you need it. He said to open up the holes in the frame brackets. I am going this route because, even sand blasted,... mine look pretty unsafe, from all the rust. Anyone else?
Old 08-02-2004, 11:32 PM   #3
SCOTI
SCOTI's Avatar
I believe the size change co-incided w/the change to discs as standard equipment.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 08-03-2004, 12:22 AM   #4
MrShelley
Too Many Clubs Club
MrShelley's Avatar
I'd like that part number. My local dealership is full of morons who would rather try to sell me a new truck than take the time to look up the part I need.
How I installed my air bags...
MrShelley is offline   Reply With Quote
Old 08-03-2004, 01:08 AM   #5
64fleetside
Just replaced them on mine, spent $10 on a drill bit, used a 1/2 inch electric drill & HANG ON! There is about three thicknesses of metal there, a little tough to drill lyiing on your back. Brian
64fleetside is offline   Reply With Quote
Old 08-03-2004, 08:22 AM   #6
lolife99
lolife99's Avatar
I will get it tonight,... after work.
Old 08-03-2004, 11:57 AM   #7
MrShelley
Too Many Clubs Club
MrShelley's Avatar
Thanks lolife
Old 08-03-2004, 10:40 PM   #8
lolife99
lolife99's Avatar
GM part number,...
MrShelley,... heres your Gm part #(345970). List price was $5.16, and dealer net price is $3.87. This is the u-bolts only! You have to provide your own lock nuts and washers. Sorry it took so long,... I had to work over tonight. Lolife.
Old 08-04-2004, 06:40 PM   #9
phantom dually
Project92 SWB stepside
phantom dually's Avatar
LMC also has these listed in there catalog I beleive.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 08-04-2004, 10:06 PM   #10
GMCGRANDS
So is there three sizes (7/16, 1/2, 9/16)? I have two crossmembers ones 7/16 and the orginal 72' one with disc brakes is 1/2".
Mark
Old 08-05-2004, 07:54 AM   #11
lolife99
lolife99's Avatar
7/16 for drum brakes, 1/2 for 71-72 discs, and 9/16 for 73-87?
Old 08-11-2004, 08:44 AM   #12
64fleetside
I have a 64,66,69,70,71, & 72 1/2 tons in my yard right now in various stages of repair/disrepair/parting. All have the same spindly u-bolts. I have seen the larger ones installed on 3/4 & 1 ton trucks. Brian
Thread Tools
Display Modes
