Old 08-03-2004, 07:34 PM   #1
JohnyCash4x4
JohnyCash4x4's Avatar
14 bolt gear ratio
Hello,
Recently bought a pieced together truck and am trying to find out what the gearing is on this beast.
The 14 bolt rear has RFZG3001 stamped on the axle tube. Is there any way to find out what the ratio was originally with this number. I have a very strong feeling it is the stock ratio for the chasis (either '76 or '79 K20).
I do know that it is the FF rear and the front is the D44 with a spool. I don't have a tach yet but the RPM's are up there travelling at highway speeds with the TH350 and 32" tires.
I'm about to build a new motor and install a new TQ converter but really need to know what I'm dealing with first.
If anyone could help it would be MUCH appreciated!
'72 C10 body on '76 or '79 K20 chasis
355/TH350/NP205/D44 with spool/14-bolt FF
JohnyCash4x4 is offline   Reply With Quote
Old 08-03-2004, 08:26 PM   #2
Russell
Professional Grade
Russell's Avatar
I'd guess either 3.73 or 4.10 if they are stock... My 80 has a 3.73 rear, and my 76 has a 4.10 year, but the 4.10 gears were an option on the build sheet for the truck.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-04-2004, 12:51 PM   #3
JohnyCash4x4
ttt
Old 08-04-2004, 01:16 PM   #4
Grim Reaper
best thing to do is take a cover off an count the teeth. No tell whats in it if they swapped them under there. they may have swappped gears as well. Personally I always service the diffs on vehciles I buy so I can see wat sort of shape the gears are in and if it has a locker.
You could jack it up and have somebody spin the wheel same direction as you and then count the tire turns till you get one turn of the pinion.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-04-2004, 06:12 PM   #5
JohnyCash4x4
Yeah, I can pop the cover but really want to know what the original gearing was so I could have an idea as to what was actually modified on this truck. Plus it may help determine what the year this chasis is so I can buy the right parts etc.
Old 08-04-2004, 08:46 PM   #6
Grim Reaper
Well the orginal to the truck is going to be on he build sticker in the glove box. If it doesn't list a gear then it's the defaul ger and most cases that's 3.08 in the 70's and som 2.75 or something on some of the 80's on half tons. 3/4 tons usualy got a 3.73 as default
Grim-Reaper
Old 08-04-2004, 08:59 PM   #7
JohnyCash4x4
lol
I don't even know what the chasis came from. All I know is it's a K20 chasis under a '72 C10 body.
Old 08-07-2004, 05:39 AM   #8
Txstruck
Txstruck's Avatar
My 14 bolt FF has 4.56 gears.
Steve
86 K30 4x4 6.2L Diesel\TH400\NP208 - 14bolt FF rear w/detroit locker and Dana60 front w/detroit locker- both with 4.56 gears "Runs on Mud"
Txstruck is offline   Reply With Quote
Old 08-07-2004, 10:03 AM   #9
stan79chevy
stan79chevy's Avatar
mine came with 4.56
from the factory in a 77 k20 with a straight 6 and 3 speed manual. i think the only gearing that came on teh ff 14 bolt was 3.73 4.10 and 4.56.
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 08-07-2004, 04:46 PM   #10
JohnyCash4x4
Yeah, I'm thinking it's at least 4.10's. I've had a few 3.73's and the RPM's this one turns at speed as far more than that even with the 32" tires.
Thread Tools
Display Modes
