Old 08-03-2004, 08:24 PM   #1
low 84
low 84's Avatar
10 to 12 bolt...what u joint do i need?
i'm swaping my 10 bolt out with a 12 bolt this weekend. what u joint do i need that will work with the driveshaft i have now and the 12 bolt pinion?
thanks
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 08-03-2004, 08:49 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Spicer 372. This ujoint has held up better than two other replacements. I like it.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-03-2004, 09:19 PM   #3
Destructo
I went to carquest and picked one up, no trouble from it yet, but it hasn't been in there very long, maybe 7 months or so. Been through hell though, VERY dusty gravel roads, off-roading, and a few thousand miles. But the Dana/spicer joints are the best and the strongest.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 08-03-2004, 10:34 PM   #4
low 84
low 84's Avatar
thanks G. do most parts chains carry the spicer joints?
'05 1500 Crew Cab
RIP
Old 08-03-2004, 11:06 PM   #5
ocbaud
Garage Queen Material
whats in the 12bolt again? i dont feel like searching. what gears did you decide on?
ocbaud is offline   Reply With Quote
Old 08-03-2004, 11:16 PM   #6
Jonboy
Slots go on anything!
When I used the 10 bolt driveshaft from the 82 Blazer in my 77 equipped with a 12 bolt, I had to use a combination joint from NAPA. Amazingly, the 12 bolt had smaller caps and cross than the 10 bolt driveshaft u-joint.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-03-2004, 11:54 PM   #7
low 84
low 84's Avatar
the joint G listed is a conversion joint. he has swapped to a 12 bolt as well.
eric, i went with 3.73 richmonds and a powertrax lock right locker. dropped the rearend off at the shop tonight to have the gears set up, should be done on thurs or fri, gonna put the rear end in on sunday
'05 1500 Crew Cab
RIP
Old 08-04-2004, 12:00 AM   #8
ocbaud
damn you. always 1 step ahead of me
why did you choose the powertrax over anything else? i'm thinking of going with an eaton and 3.73's
Old 08-04-2004, 12:12 AM   #9
low 84
low 84's Avatar
basically i got a good deal on it and i liked the idea of going with a locker. as long as i'm accelerating the axles are fully locked together. no clutches to slip or wear out. i'm not saying that would happen with an eaton but i got a good deal on it so i decided to use it.
'05 1500 Crew Cab
RIP
Old 08-04-2004, 12:14 AM   #10
low 84
low 84's Avatar
and as far as being 1 step ahead of you, i had this 12 bolt for 1 1/2 years just be sitting in the garage wait for me to get the money to build it
'05 1500 Crew Cab
RIP
Old 08-04-2004, 02:58 AM   #11
gchemist
gchemist's Avatar
NAPA has the joints in stock. Not sure about other stores. They can probably order them though.
Old 08-04-2004, 03:08 AM   #12
jimfulco
My NAPA guy didn't have one in stock, so he made one from 2 others, & only charged me for one.
jimfulco is offline   Reply With Quote
Old 08-04-2004, 04:09 AM   #13
1972C10
1972C10's Avatar
Presicion part # 447
1972C10 is offline   Reply With Quote
Old 08-04-2004, 01:58 PM   #14
Grim Reaper
You got the 10bolt...swap the yokes. It takes a different seal but they are readily available. bring both the 10 and 12's seal. They need to get the numbers off each and then they can cross refference it. The 10 uses a stronger u-joint. Go to NAPA. Autozone people are too stupid to do this.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-04-2004, 04:07 PM   #15
swervin ervin
You get what you pay for
swervin ervin's Avatar
Shame on you. Now what in the world makes you say such things?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 08-04-2004, 05:44 PM   #16
Grim Reaper
The zit face honda driving punk that told me a 297 U-joint for a front axle U-joint on a 1979 K5 was a dealer only part.
Grim-Reaper
Thread Tools
Display Modes
