Old 08-04-2004, 12:08 AM   #1
johnleewilson
Talking show me your electric fan!
show me your electric fan conversions. does it add horsepower? if so how much? whats the cheapest way to go? post me some pics so i can see what a good set up is. thanks
john~!~
johnleewilson is offline   Reply With Quote
Old 08-04-2004, 12:15 AM   #2
ocbaud
Garage Queen Material
they dont "add" hp, they just free it up
ocbaud is offline   Reply With Quote
Old 08-04-2004, 12:20 AM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Here's mine. Dual 14" Spals.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 08-04-2004, 12:28 AM   #4
Russell
Professional Grade
Russell's Avatar
These will be going onto my truck soon:
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-04-2004, 06:03 AM   #5
Nvbowtie
Nvbowtie's Avatar
154.00 bucks at Checker
http://www.partsamerica.com/PartDeta...pe=528&PTSet=A
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 08-04-2004, 07:36 PM   #6
johnleewilson
sooooo.. does it "free up" enough horsepower to make it with my while? not that 150 is too bad at all, but there any cheaper fans that still do the trick?
Old 08-04-2004, 08:19 PM   #7
Russell
Professional Grade
Russell's Avatar
Sure are, run off to your local wrecking yard and pick up a set for like 30 bucks, and just buy / build a wiring harness for it, you'll also need a relay thats hooked up to a temp switch, which you can buy cheaply pretty much anywhere.
Probally get it done for under 100 bucks if you went the wrecking yard path. You can use electric fans from most any car if you did some fabbing to fit them up. Not sure which cars in specific is the one with the dual fans that fit perfectly (mine are from a 350 TPI Camaro, and are controlled by the ECM that will be in my truck to control my TPI) But there are a couple out there.
Old 08-04-2004, 08:26 PM   #8
bigblock73
yeller
bigblock73's Avatar
Here is mine, sorry...I couldn't resist.
When time and money allow, I wil be setting my truck up similar to Mikes, Spal fans are great and have a very good rep.
bigblock73 is offline   Reply With Quote
Old 08-04-2004, 08:48 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by bigblock73
Here is mine, sorry...I couldn't resist......
That was a good one Jeff....
Here's mine....
Old 08-04-2004, 10:27 PM   #10
1980chevy4x4
Got Mud?
Do you need 2 or will one 16" be okay?
Dan
Got mud?
1980chevy4x4 is offline   Reply With Quote
Old 08-04-2004, 11:05 PM   #11
Russell
Professional Grade
Russell's Avatar
I guess it depends on how much air it moves, most often an electric fan moves more air than a stock fan, so, just a stab in the dark here, I'd guess that a single 16 would probally be fine...
Old 08-05-2004, 12:07 PM   #12
cochino12
It followed me home?
cochino12's Avatar
Anyone have pics of the mounting they used? Swervin is that a small shroud that go around yours?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-05-2004, 12:22 PM   #13
Grim Reaper
Ford windstar fans are a good junkyard score and have a sroude on them that woulds pretty good on our radiators. Ford Taurus 2 speed fans are also not a bad junk yard score.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-05-2004, 11:32 PM   #14
swervin ervin
No. Don't have a shroud. Here is a very old pic of what they looked like right after I installed them. I have dolled everything up some since. I have a stainless steel cover over the radiator now, along with some other engine bay dressup stuff. The metal straps is what came in the kit I bought. They have two more on each fan at the bottom also. The fans sit right against the radiator. No shroud is needed anyway. Folks think you need a shroud with electric fans. This is something a lot of fan companys try to make everyone think. It's a way for them to sell cheap, underpowered fans. Folks will buy pretty before quality. You know?
Thread Tools
Display Modes
