Old 08-10-2004, 07:02 AM   #1
1986Silverado
What I drive
1986Silverado's Avatar
Battery or alternator???????
Got in my truck to come home this morning and it would not start. All lights came on and did not seem dim. Left the light on and tried to crank it, lights went out, let off the switch and they came back on. Well got it jump started. I noticed on the drive home the volt guage would be at 13 while moving at about 45mph, but when I slowed down it would gradually go down towards the red line. And at a stop light it was just above the red line. Got it home, shut it off, tried to crank it back up and it turned over really slow and drained almost immediately. Is it the battery or alternator?
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 08-10-2004, 07:56 AM   #2
GMCLS1
1987 GMC Sierra Classic
GMCLS1's Avatar
Sounds like the alternator.
Gary L Hilton jr
GMCLS1 is offline   Reply With Quote
Old 08-10-2004, 09:05 AM   #3
Grim Reaper
Good chance both. Battery ate it and burned up the alternator. I would start with the battery and have it tested.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-10-2004, 12:02 PM   #4
76sierraclassic
Could be the other way around too. If the alternator bit the dust, you would have been pulling juice directly from the battery and could have cooked it. But I agree with Grim, have the battery checked first. Then, even if you change it and everything seems ok, I'd still have the alternator tested too. Pretty much any auto parts store will check it for free, and they can usually check it while it's still on the truck.
Mike
76sierraclassic is offline   Reply With Quote
Old 08-10-2004, 12:25 PM   #5
Russell
Professional Grade
Russell's Avatar
The poor man's way of testing the alternator is to pull the postive battery cable off the truck when it is running, if it dies, the alternator is definitly done, but also check the voltage coming out of the alternator, should be like 14 volts or something.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 08-10-2004, 04:16 PM   #6
1986Silverado
What I drive
Went outside to work on it and it is completely dead, no lights, nothing. So I put my marine battery in it, fired right up. I pulled the positive battery cable and it died instantly. Gonna pull the alt off and go have it tested tomorrow, no time today.
2006 Chevy Equinox
Old 08-10-2004, 04:23 PM   #7
Russell
Professional Grade
Russell's Avatar
That tells me your alternator is fried, too bad you arn't a bit closer, I have like 4 of them, lol
Old 08-10-2004, 04:49 PM   #8
1986Silverado
What I drive
Yep, by the way Russell, could you send me a pic to my email of one of those Canadian speedo's? May try one just for looks
2006 Chevy Equinox
Old 08-10-2004, 06:14 PM   #9
Russell
Professional Grade
Russell's Avatar
You have mail!
Old 08-10-2004, 11:29 PM   #10
blink32
blink32's Avatar
Another easy way to test the alt is with any kind of volt meter. I have a cheap $5 analog unit I use. You just start the vehicle and while its running, put the + of the tester to the + on the alt and the - of the unit to a good engine ground. Meter should read in the 14+ volt range. The exact voltage will be in a manual some where, but other vehicles I have worked on always called for 14.1 - 14.4 volts at the alt when running. If you don't get that voltage then its time for a rebuild or a new one.
blink32 is offline   Reply With Quote
Old 08-13-2004, 03:30 PM   #11
1986Silverado
What I drive
Turned out it was both, the battery would not hold a full charge and the alternator was not putting out any voltage............replaced both and it fired right up!
2006 Chevy Equinox
Old 08-13-2004, 05:10 PM   #12
Russell
Professional Grade
Russell's Avatar
Good to hear you got her working
Old 08-13-2004, 07:40 PM   #13
SanitysBane
off topic-russell, looks like you can make some good money selling the canadian clusters to us americans
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 08-14-2004, 12:20 AM   #14
cliffsta
Stepsides RULE
cliffsta's Avatar
yeah my battery is on its last leg. volts fluxuates between 14 and 10, independant of speed.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Thread Tools
Display Modes
