Old 08-14-2004, 02:16 PM   #1
BobM
700R4 Rad Cooling Lines
Anyone know the correct way to connect up the transmission cooling lines to the radiator? Do they go top transmission fitting to top rad fitting and bottom to bottom? Or, are they reversed, top to bottom and bottom to top? Or....does it matter?
BobM is offline   Reply With Quote
Old 08-14-2004, 04:07 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It does not matter if you are on,y going to use the cooler in the rad.
Old 08-14-2004, 10:58 PM   #3
Shane65
The upper connection on the trans is the return line from the rad(in case you want to run an additional cooler after the rad cooler).
Shane65 is offline   Reply With Quote
Thread Tools
Display Modes
