Old 08-15-2004, 10:48 PM   #1
SixthFloorFreak
Putting spindles on...what to replace?
I'll be installing my DJM spindles here pretty soon. I figure since i'll have the front end tore apart, i ought to replace bearings, bushings, etc...
What all should i check/replace?
SixthFloorFreak is offline   Reply With Quote
Old 08-16-2004, 02:14 PM   #2
1986Silverado
What I drive
1986Silverado's Avatar
bearings, upper and lower control arm bushings, upper and lower ball joints, tie rod ends. hope that helps
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 08-16-2004, 03:23 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Keep in mind that there are inner and outer tie rod ends... It is also a good time to replace your springs if they are worn, or if you want to use drop springs.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-16-2004, 11:49 PM   #4
SixthFloorFreak
thanks guys
Old 08-16-2004, 11:52 PM   #5
SanitysBane
get a supesion rebuild kit, but thats just me
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 08-17-2004, 12:02 AM   #6
ocbaud
Garage Queen Material
yes.
and use plenty of bearing grease, or else you will regret it later and need to buy new spindles
ocbaud is offline   Reply With Quote
Thread Tools
Display Modes
