Old 08-18-2004, 10:43 AM   #1
mckpaul
mckpaul's Avatar
Oil pressure gauge reading.. is it too low??
I'm sure this has been answered in the past, but can't search to find it.
Got a stock 305 with a 60 psi oil pressure gauge. What's normal for a reading on this gauge on a running engine at idle speed?... at driving rpms? Just finished a stock rebuild on the motor including a new oil pump, ran with the old sending unit for a while, replaced it yesterday. The gauge is responsive to changes in engine speed, but reads lower than what I would expect. At driving speed rpms it reads somewhere between 15 and 30, and at idle drops down below 15. I know I have enough pressure to close the oil pressure switch by the oil filter that sends voltage to the choke heater and turns off the choke light, so if I didn't have a gauge and only had an idiot light, I assume in reality I have enough pressure that the idiot light would be off, but it seems strange to me that the 'normal' range on the gauge would be down in the first 25% of the scale and not around the middle. Do they all read low like this or do I have an oil pressure problem????
Paul
1984 Chevy C-10
*LWB/305*
mckpaul is offline   Reply With Quote
Old 08-18-2004, 10:58 AM   #2
GMC AMI
GMC AMI's Avatar
Low oil pressure?
If the gauge is correct than your oil pressure is a bit too low. It should be around 30 lbs at idle is more normal, a little higher a highway speeds. You may have a bit too much clearance in the main berrings. If the oil pressure cold is higher than when warmed up, my guess is the mains and not an oil pump problem. By the time the idiot light would indicate and light up the damage is done so the saying goes and there is a lot of truth in the statement.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 08-18-2004, 11:26 AM   #3
'85Silverado
Before you get too carried away, I would verify the pressure using an aftermarket mechanical guage. What oil and filter are you using? On the rebuild, what did you do to the crank? Plastigauge the bearings?
85 Silverado, (new project)
96 Tahoe, Family Car
82 Camaro, for fun
My dad has
70 Chevy short-wide resto in progress
68 Chevy daily driver
99 Tahoe
'85Silverado is offline   Reply With Quote
Old 08-18-2004, 11:56 AM   #4
mckpaul
mckpaul's Avatar
On the rebuild, I took the crank, cam and block to my local machine shop. He was able to get a 'kit' from a supplier with everything for the rebuild (including the oil pump)tweaking bearing and ring sizes as needed. He was pretty impressed with the lack of wear on the cam and we reused it, he said the crank wasn't worn enough to merit going with over sized bearings, so the mains (and connecting rod inserts) are new standard sized on a slightly worn crank that he polished. (Keep in mind this isn't a performance vehicle, or even daily driver, just a second vehicle to have a truck around the house, wasn't even going to rebuild the motor before dropping it in, but one thing led to another while I had it on the stand and I did it anyway)
Thought about finding a way to measure the pressure with a gauge other than the one in the dash, not sure what to use or where to get it. If I find an aftermarket mechanical gauge, would I connect it in place of the sending unit (at the back of the intake manifold) or could I connect it where the other switch is by the oil filter?
As for oil, it's Pennzoil, I think 10W-30, and the filter is Fram.
Oh, and by the way, I've had the instrument cluster out recently to replace all the bulbs, and made sure all electrical connections and grounds were good. The ground strap from the head to the firewall is in place as well. After doing all that, the fuel, battery, and temp gauges are solid and accurate, unlike before when they seemed to wonder around.
Paul
1984 Chevy C-10
*LWB/305*
Old 08-18-2004, 12:01 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
That is normal range for a stock bottom end and pump. Typically it is about 10 at idle and 5lbs for every 1000 rpms.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-18-2004, 12:25 PM   #6
mckpaul
mckpaul's Avatar
^ That sounds encouraging. I used to have a 77 Silverado many years ago with a 350. Seems like I remember it reading low too, but it had a lot of miles on it. Guess I'm just being a worry wart since I just rebuilt this one, makes me go back through everything in my head wondering if was a little off on something somewhere in the rebuild process. It's not my first overhaul, done three or four over the years.
Paul
1984 Chevy C-10
*LWB/305*
Old 08-18-2004, 04:43 PM   #7
cliffsta
Stepsides RULE
cliffsta's Avatar
my 305 stays around 20-30 at idle in park, and in the gas it acts normal. Since its a new engine im assuming the oil has been changed a few times. if its hot outside and you're running 10w30 then that still is a bit low, but remember that if its hot oil pressure will be low.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 08-18-2004, 04:51 PM   #8
Destructo
I get about 15 psi at idle on my 350 and its been like that daily driving it for over a year now with no issues. Goes up to around 30-40 while cruising.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 08-18-2004, 05:16 PM   #9
mckpaul
mckpaul's Avatar
No it's till the original oil, only put about 60 miles on it so far going out for short runs to get the bugs out, no inspection yet, no registration yet due to no passed emission test yet, working on getting all that put back in place now. Anxious to see if it changes after I get inspection and tags and can put some miles on it, get things seated and broke in and change the oil a couple of times. Gonna have to look and see what weight oil I used.
I apperciate the input!
Paul
1984 Chevy C-10
*LWB/305*
Old 08-18-2004, 05:53 PM   #10
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
IMHO, that reading is too low. I have rebuilt a ton of SBC's and have never had one that read lower than 25psi idling hot. Personally, I rebuild my own engines (including checking all clearances) because I don't trust anybody else's opinion on what's "within spec". I trust my machinist, but I ALWAYS double-check his work. After all, it's not his money that was spent and it's not his engine. I've seen freshly machined cranks that were a mile out of spec, due to sloppy machining. Also, never just slap in a new oil pump. Many come with improper gear end clearance, right out of the box. Depending on just how far off it is, this can drastically affect oil pressure. The proper spec for BBC and SBC oil pump gear end clearance, is .0025". I recently bought a Melling HV oil pump that was at .0075"!! Took some serious time and elbow grease to blueprint that sucker. Proper clearances will ensure good oil pressure.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 08-18-2004, 08:23 PM   #11
mckpaul
mckpaul's Avatar
Hmmmm.... well, I did my own rebuild, machine shop polished the crank, did the heads and got the block ready for me, did the measurements and got the parts. It is a Melling pump, not a high velocity though.
Guess my next move is to get a pressure reading with something other than the gauge in the dash and see what the actual pressure is. I'm thinking a mechanical pressure gauge that goes to about 50 or 60 psi with a pipe thread? Just a basic screw in gauge? And would the pressure be the same at the location where the switch is by the oil filter as it would at the location that feeds the sending unit (the one by the oil filter would be easier to access to screw a gauge into)?
Paul
1984 Chevy C-10
*LWB/305*
Old 08-18-2004, 08:48 PM   #12
screwballl
Tonawanda 454
screwballl's Avatar
with my stock 76 and 350, mine reads 35psi or so cold (just after startup) and when running down the road at more than 20mph. After its warm and idling liek at a stoplight in gear and at a complete stop, it usually reads around 10psi, if i put it in neutral or park then it goes up to around 15-18psi unless the oil is low then it stays 10 or so.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 08-18-2004, 09:19 PM   #13
1FaastC10
1FaastC10's Avatar
there you go right there... if in fact your guage is accurate, there is your problem. excessive bearing clearances at the crank.
1FaastC10 is offline   Reply With Quote
Old 08-18-2004, 09:50 PM   #14
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Dont forget that the idle rpm will have influence on the oil pressure reading. I get a different reading for the oil pressure for different idle speeds 500-900 rpm. At 500 rpm the oil pressure was a lot lower than when it was idled higher.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-18-2004, 10:38 PM   #15
aliencheyenne
Switch to 20-50 and see if it makes a difference
aliencheyenne is offline   Reply With Quote
Old 08-18-2004, 11:23 PM   #16
Destructo
Probably should have used some .001" undersize bearings on a polished crank. I think they make bearings specifically for use on cranks that have been polished.
Old 08-19-2004, 09:14 AM   #17
mckpaul
mckpaul's Avatar
OK - Started it up last night and watched the gauge closely. Cold idle it came up from 0 and read slightly above 15 (assuming that mark in between 0 and 30 is 15) maybe about 17. When I'd rev the engine, it would go up about 2 more psi and drop back when I let off. What seemed weird to me it that the gauge doesn't just move up, it kind of clicks up, or immediately jumps up a little on a rev, and then jumps back down when I let off, a much faster response than I'd expect to see if it really was just a couple of psi increase.... OK, wishfull thinking on my part...
Assuming the pressure is a little low due to excessive clearances, would it help to change the oil pump to a high volume pump? Autozone shows to carry a high volume Melling pump with a comment "MUST USE INTERMEDIATE SHAFT WITH STEEL GUIDE". By that, are they referring to a steel equivilent of the teflon coupling piece that came with the regular Melling pump that keeps it engaged with the distributor shaft?
In hind site, guess I should have posted this in engines and drivetrains, but thanks for all the input, much appreciated!
Paul
1984 Chevy C-10
*LWB/305*
Thread Tools
Display Modes
