Old 09-04-2004, 12:36 PM   #1
ocbaud
Garage Queen Material
cheapest place to buy posi/gears??
i'm looking for the cheapest place to order an eaton posi unit for my 10-bolt rear end and some 3.73 gears to go with it. i've currently got 2.73's
ocbaud is offline   Reply With Quote
Old 09-04-2004, 05:04 PM   #2
TIMSPEED
TIMSPEED's Avatar
West Coast Differentials
Randy's Ring & Pinion
National Drivetrain
Drivetrain Superstore
Check out those three places.
I'm going to get my posi/install kit from West Coast, only because they're about an hour away.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-04-2004, 05:45 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
When your getting price quotes, ask what they charge for and what is included in the install kit. I bought my Richmond Gear 3.73's and install kit from Summit. The price was the best I could find at the time. When I installed it I had to but axle bearing and seals locally because it didn't come with the install kit.
It didn't really "need" the axle bearings at the time but while it was apart I wanted "everything" to be new....
Old 09-05-2004, 12:54 AM   #4
ocbaud
thats what i'll be doing. replacing most of the parts that i can. gonna get a nice alum. differenial cover, new bearings, seals, etc...
randy's rind and pinion is the place i remember. they had the cheapest posi unit i've found
Old 09-05-2004, 03:49 PM   #5
STEPSIDE_84
jegs has a seperate install kit for our trucks w/richmond gears ($130) any idea if this is worth the extra money or just buy the complete kit for 90
also looking to upgrade gears
STEPSIDE_84 is offline   Reply With Quote
Old 09-05-2004, 04:29 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Summit and Jegs are going to be free shipping. Think about that if someone else seems cheaper, because those gears and differential are heavy as heck and UPS is going to hurt you a little on shipping prices.
Old 09-07-2004, 01:22 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I got mine from Randy's. I told them I needed the kit to replace everything in the rearend except the axles.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-07-2004, 02:00 PM   #8
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb
Eric,
Have you ever considered using a PowerTrax posi unit there really easy to install and no special tools or expensive posi gear oil is required and they preform as good or better than any clutch disc posi unit iv'e ever used.
I know you will have to set the rear end up anyways when you install the new gear set but any time you open the rear up for routine maintenance BAM! 40 bux for posi gear oil
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 09-07-2004, 04:15 PM   #9
STEPSIDE_84
about how much does it cost to get them installed
Old 09-07-2004, 06:45 PM   #10
RockHQ
ROCKET POWER!
RockHQ's Avatar
I just bought a PowerTrax No-Slip locker for my 12 bolt. Haven't installed it yet though, waiting on my ring&pinion&install kit. But it sure is a NICE piece of equipment, and like said no cluthes to wear out or cones to bottom out.
BTW, most install kits i've seen do not come with wheel bearings&seals, but it should not be a problem for anyone.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Thread Tools
Display Modes
