Old 09-05-2004, 12:01 PM   #1
crustysarge
Emissions part???
This is located on the pass side on the intake. It has 3 wires and a vacuum source from the carb. I noticed it had a line with a screw so I put a vacuum cap on it.
What is this device? Where does the vacuum line go to? I also see what appears to be another nipple on the backside by the elect. plug.
Anybody have a 72 vacuum diagram they could share? Mine is a 350.
crustysarge is offline   Reply With Quote
Old 09-05-2004, 02:33 PM   #2
J.Lance
Too many is never enough!
advance cut off
It is somewhat emissions related. It is a vacuum advance cutoff. It basically allows no timing advance until the motor has warmed up to operating temperature. The wiring would connect to one or two relays attached to the firewall either next to the fuse block or near the heater box. A 2nd temp. sending unit located on the passenger side of the block would trip the solenoid and open of vacuum to the distributor when it warmed up. If you look on the passenger side of teh block between the 6th and 8th cylinders, you should be able to see the sending unit or at least a plug where it once was.
Unless you're going back to stock, feel free to remove it along with the associated wiring. Your vacuum advance for the dist. should be hooked up to the carb where the vacuum solenoid is currently hooked to (ported vacuum). The wiring harness going up to the relays on the firewall and down to the sending unit is self contained and can be removed without cutting into any of the engine harness.
Hope this helps you out.
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 09-06-2004, 09:43 AM   #3
crustysarge
Thanks J. I would have never guessed that. PO installed an HEI and I was just about to check the ported advance and change wires as they are arcing.
Old 09-07-2004, 03:04 AM   #4
jimfulco
TCS? Cuts off vacuum advance except in high gear.
jimfulco is offline   Reply With Quote
Old 09-07-2004, 10:40 PM   #5
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
Must be a California truck or something, my 72 was all original and it never had anything like that.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 09-07-2004, 11:05 PM   #6
aesj2
TCS. Had a 72 Blazer with that. Built and sold in Michigan.
aesj2 is offline   Reply With Quote
Old 09-08-2004, 06:10 AM   #7
JimKshortstep4x4
Smile
The TCS system was not installed on the C 20 trucks and larger.
Jim
Old 09-08-2004, 11:05 AM   #8
72C203503ONTHETREE
Ok, didnt think about that. Glad I don't have any of that crap to remove on my truck.
Old 09-10-2004, 05:13 PM   #9
crustysarge
Pretty sure it is from Arkansas.
Thread Tools
Display Modes
