![]() Join Date: Dec 1999
tranny problem giving me a bad feeling
i dropped in my newly rebuilt turbo 350 and 350 engine about 4 months ago. then spent the last 4 months putting the engine together and finally fired it up about a week ago.
i ran the engine long enough to flush out my cooling system and tune my injection at idle. next step was to tune the idle in drive. i had about 4 qts of tranny fluid already in the torque converter so i put another 8 qts in through the filler. started her up and put it in drive, nothing happened. no shift at all. the only thing i noticed was the front driveshaft start spinning, then gradually stop when i put it back in nuetral. then if i paused for a second in reverse before continuing to park, there was a whining noise. i smell trouble. any suggestions? questions about where i might have went wrong? ![]() please dont tell me the trannys no good and have to pull it out
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
That sounds like a tought one. The only thought that comes to mind is the torque converter is not engaged in the front pump.
Jim |
mind if i change the subject of the thread to 'im an idiot and have no right to participate on this board bringing up stupid problems like this'
i had the $#%!%* transfer case in nuetral. im going to hide under a rock ![]() ![]() ![]()
blood type; Retumbo
you beat me to it. I was going to aks about that.
dont worry about it, you are human just like the rest of us. so how does it run-shift? burn-out pics soon?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
well it died the first time i put it in gear. it was just a little lean fuel mixture around that idle area but its all tuned and ready now.
the burn out pics will definitely be a while. i still have no fenders, doors or hood on
Thread Tools | |
Display Modes | |
