Fabricate till you "puke"
"new" exhaust on the 69
About a week ago, I salvaged a used set of 50's flows from the junk pile down at the muff shop,& stuck em on the 69(a little paint 1st). Yesterday, she went down to the shop, & my youngest (15 yr old kid) gave me a hand setting up the tailpipes(it was a fun time!).....altho, the kid did not like hot sparks! the system runs 2 1/2 " pipe from the back of the Hooker comps, H pipe(2 1/4"), & the flows are hung about 1 ft or so behind the cab. the tail pipes are also 2 1/2", & wrap up over the axle, around the fuel cell, & through the back bumper......man does that sound nice
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
blood type; Retumbo
about the same time I put some temporary pipes on mine. Hedmans from KurtL, a pair of 12" glasspack & 2 1/2" pipes with a 45 bringing them out just in front of tires. it sounds scary when I get on it. 3000 rpms under hard accell will make for a un-obstructed entrance into an intersection! I think I will have to eventually do something different just to keep officer Friendly off my ass.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
I had those tubes poked out the sides,just ahead of the wheels(like to hear em run!) the old man i am working for said "now if you can get that sound on the back of that truck, you will flat @ss have it".....got it!
blood type; Retumbo
one advantage of having it come out in front of the tires is ppl tend to stay out of my blind spot.
#5 | |
Speed Limit = Floorboard
1971 C20 350, 4-speed - Sold. 1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project. "Build for torque, horsepower will follow" |
Thread Tools | |
Display Modes | |
