Old 09-06-2004, 05:26 PM   #1
TIMSPEED
TIMSPEED's Avatar
[Pic] Here's where my LCA scrubs...
Can I just grind a little off the LCA, because it's just a MINUTE amount that scrubs, and it only does it when I'm at FULL LOCK right turn.
You can see in the picture where the wheel weight has been ground off the edge.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-06-2004, 06:12 PM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
Ever thought about 20's, Tim?
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 09-06-2004, 06:37 PM   #3
SCOTI
SCOTI's Avatar
Even 20's will rub if there's too much offset (they'll just rub in a diff place).
No Tim, it won't hurt to trim it back. I typically trim mine all the way to the shock mount w/o issue. Just don't straight cut it though (90° cuts will cause stress cracks). Use a 7/16" drill bit @ the end of the area your going to trim to so the end of the cut is rounded instead straight.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-06-2004, 06:50 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
You could just not turn all the way to the right. :p
swervin ervin is offline   Reply With Quote
Old 09-06-2004, 07:03 PM   #5
TIMSPEED
TIMSPEED's Avatar
It's seriously so embarrasing, I usually DON'T turn all the way lock-right. But I will do what Scoti suggested, thanks
See Them Here
Old 09-06-2004, 09:37 PM   #6
BaggedC10
Under construction!
BaggedC10's Avatar
I know. I'm trying to sell him my wheels/tires.
Old 09-06-2004, 09:44 PM   #7
TIMSPEED
TIMSPEED's Avatar
Haha, and I wanna buy em...I'm just a broke kid
See Them Here
Old 09-06-2004, 10:04 PM   #8
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
If I had that problem, I would use more throttle to swing the backend around.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-07-2004, 08:08 AM   #9
SCOTI
SCOTI's Avatar
Ahhhhh......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Thread Tools
Display Modes
