09-12-2004, 07:29 PM | #1 |
[Pic] 5" Front Drop is DONE!! B)
MAN! It's SWEET! FINALLY both front fenders are the same heighth. (Perfectly 28" on each side) I would say I put the coils in wrong, but since both fenders are the same heighth, I musta done it right.
Also, for anyone thinking (coughcoughEriccoughcough) that a 255/55 17 won't work with 5" front drop...You're WRONG!! I still have a CLEAR 1" of space between the tiretop and the fender. (But I DID roll the fenders, just as a precaution) In the pic of the coils, I have them sitting upside down, so the name is right side up. Sorry for the horrible picture of the truck..I'll get a better picture 2moro when the lighting is better. |
09-12-2004, 07:46 PM | #2 |
Can you jack up the truck by the K member and not have the springs fall out of the cup?
09-12-2004, 08:54 PM | #3 |
You gonna leave it with that rake? Looks good BTW. Or are you gonna lower the back some more?
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
09-12-2004, 09:25 PM | #4 | |
Gary, Thanks Yup, I'm gonna leave it with this rake, for now. It will have a little less rake when I move the gas tank to the back (fuel cell) and have it full. (Currently, EMPTY on gas) |
09-12-2004, 09:31 PM | #5 |
Happy to be here
WOW! Tim you finally put a plan into action. I'm really proud of you
Now we need some real pics.... |
09-12-2004, 09:39 PM | #6 |
Watch out for your cornhole !
Did you buy them as Ground Force springs or Summit brand springs?
I buy a bunch of Summit brand springs and they are actually the blue Ground Force ones like that. I have them under both my 77 Blazer and my 70 short bed.
09-12-2004, 09:53 PM | #7 | |
09-12-2004, 10:10 PM | #8 |
Under construction!
Looks better, Tim! When are you going to bag' it?
2001 Silverado bagged on 22's. *Sold* |
09-12-2004, 10:43 PM | #9 |
yup, summit brand is just no name stuff made by a name brand company, like the gears for my rear-FOMOCO (authintic ford)
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
09-12-2004, 10:44 PM | #10 |
Ive got some cut down springs on my 72 it only lowered it 3 inches and i cant jack my truck up by the crossmember Otherwise the springs will fall down and i have to line them back up with the upper alingment dowel.
09-12-2004, 11:12 PM | #11 |
Hotwheels?
they will prolly settle some more. You will get more drop!
1978 Money Pit - CUSTOM DELUXE!!!! |
09-13-2004, 12:04 AM | #12 |
Garage Queen Material
i never said they wouldnt work, i said they are to tall for me
09-13-2004, 12:11 AM | #13 | |
09-13-2004, 04:34 AM | #14 |
Right turn Clyde
It is very possible that you didn't get the coil spring in the pocket right. I did this when I installed my HD coil springs in my truck recently. There was 1/4 difference in mine when measured. I did go back and put them in the right way. It was my first time and I didn't even notice the spring pocket until I was doing the passenger side, started on the driver.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
09-13-2004, 10:20 AM | #15 |
I'm PRETTY sure I got them into the pocket correctly. On the top, that little round thing is inside the small coil, and on the bottom, the coil covers the drain hole. I think it's right, because 28" is right where the fender SHOULD be. (Stock I put 32" tires on, and with 5" drop I have 28" tires on, makes sense)
09-13-2004, 10:27 AM | #16 |
when i lowered my truck, after a little while driving it(say around 10 minutes) the springs, popped into place and it lowered it a good inch or so.
09-13-2004, 01:57 PM | #17 |
When I put my 3" springs in, I could jiggle them side to side. I had to get my wife to lower the floor jack while I held them in place. However I have since rotated my tires and for some reason they stay in place now.
Are those your stock unmodified springs in the picture Tim?
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
09-13-2004, 03:16 PM | #18 |
Looks good, now you need some paint!
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
09-13-2004, 03:28 PM | #19 | |
09-13-2004, 06:03 PM | #20 |
Mudslides 'r my specialty
I think that rake looks good. The fender lips are almost level.
If it does drop a little more in front, just install a bumper and your tailgate and you should be good to go.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
Thread Tools | |
Display Modes | |
