Same difference? (Rearend qustion)
What is the difference between a locker and posi? For the longest time I thought they were the same, but my cousin told me that they are different. He couldn't explain it very well, so I was hoping someone on here could shine some light on the subject. Thanks for your info.
-Brandon |
Brandon,
I am gonna take a quess here but I think a locker lets you unlock and lock it at will and a posi works all the time. They both accomplish the same mission just in different ways. I don't like a posi rearend because on ice or packed snow, the back end comes around real easy. |
The locker and posi both help you gain traction, but they are not the same. Any kind of locker will "lock" the axleshafts together, so they spin at the same speed. Some lockers allow the axleshafts to become unlocked when turning, so the wheel speeds can differentiate. Some lockers are engaged with the flip of a switch or push of a button, and will behave like spools (permanently connects the 2 axleshafts) until they are unlocked. Sometimes the axles wont always unlock, and lockers are known for accelerating tire wear when driven on the street.
Posis (or limited slips) have some sort of device inside the carrier to make the axleshafts connect to spin the same speed, but they do not work all the time and can sometimes even get worn. The most common posi uses clutch packs to make the axles resist moving at different speeds. There are other types, such as gear driven and governor driven. Posis generally don't have as bad of handling characteristics as lockers. I know I am probably leaving a few things out, but hopefully this helps.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
i love my detroit locker! it alows for differnt tire speed up to a point, and then it acts like a spool, and maybe i am getting a little more tire wear, but i would prefer it over a posi any day, the clutched wair out over time.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
Thread Tools | |
Display Modes | |
