Old 09-13-2004, 10:39 AM   #1
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Hinge pins
Looked around on the paint and body board for awhile but didn't see anything. I tried to get the old pins out but they don't seem to want to come out. Is there some kind of small retaining device I missed that is unique to factory door pins? My cheapo Chilton's book is no help either. Would appreciate some advice. Thanks.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 09-13-2004, 11:18 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I assume you are talking about the door hinge pins. Some pins are swedged at the bottom (flattened slightly to prevent them from walking up). If you can see a "squished" portion of the pin you can cut it off with a dremel and then drive the pins out. Also, if the pins are very worn, you may have to get the hinge lined up just right to allow the non-worn portion of the pin to pass cleanly through the hinge.
NeCrOmAnCeR is offline   Reply With Quote
Old 09-13-2004, 12:08 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
How hard is the top one to replace? Bottom one looks real easy.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-13-2004, 03:30 PM   #4
flip66
flip66's Avatar
Easiest way I have found to them is to mark the hinge mount, put a jack under the door to hold it and take out one replace the pin put it back and do the other one. If you mark it should line right back up.
flip66 is offline   Reply With Quote
Old 09-14-2004, 12:09 PM   #5
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Thanks for the info
Brad
79 Scottsdale C20
350/350
3.73's
Thread Tools
Display Modes
