09-16-2004, 11:16 AM | #1 |
Will the steering box off a 87 IROC fit a 72 frame??
Any ideas??
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
09-16-2004, 11:57 AM | #2 |
Im pretty sure that one is on the inside of frame and the truck is on outside, So it would be upside down.
1971 LWB Chevy C-10 350/350 3:42 eaton |
09-16-2004, 03:59 PM | #3 |
its all about the +6 inches
It won't fit.
09-16-2004, 04:10 PM | #4 |
Sorry. As I won't have the car home until sunday, I haven't looked at the position of the steering box.
09-16-2004, 08:03 PM | #5 |
Got Light Emitting Diode?
what is it 69-87 1/2 2wd steering boxes are all the same??? there pretty easy to find, and cheap too
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
09-17-2004, 01:26 AM | #6 |
68-84 power steering boxs will fit but in 73 they changed the water pump to a longer neck. you can use a 73 and newer pump but you have to change the water pump and move the alternator to passanger side you will need;power steering pump,brackets,water pump ,pitman arm,alt brackets,and pulleys off a 73-84 truck i can have pics i done this swap on my 72 1-ton[all 1/2 to 1-tons run the same stuff]. about2-3 hours to do it is all bolt in.if you can find the 68-72 [steering ]pump the hoses will match with the newer steering box and add the drive pulley you do not have to every thing else .
09-17-2004, 02:22 AM | #7 |
Merciless Butcher
It is a whole lot easier to use a 73+ pump and use brackets for a short water pump (they will bolt right on). I have seen the brackets for the power steering pump with a short water pump in several catalogs. Corvettes used the short waterpump up until the early eighties with the newer style power steering pump. You won't have to change anything else.
Your Bought And Sold....I Got Your Soul! |
Thread Tools | |
Display Modes | |
