Old 09-28-2004, 03:41 AM   #1
chevy69er
4 Wheel Disc Brakes
Well im gathering all of my parts to convert to disc brakes in the rear.Its a 69 3/4 ton.I would like to use a corvette master cylinder and porp. valve but i cant remember what year will work best for my application.Any help on this would be appreciated.Thanks!
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
Old 09-28-2004, 06:49 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
MC from a 78 Corvette,rear calipers from a 84 Cadillac Eldorado(has parking brake in it)Caliper mounts from TSM.
That's what I have on my 71 Blazer anyway.
This is the best pic of my Corvette MC I could find
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-28-2004, 09:08 AM   #3
Mudder
Mudder's Avatar
How does that parking brake work? original cable or??????
Mudder is offline   Reply With Quote
Old 09-28-2004, 12:00 PM   #4
drink2mny
drink2mny's Avatar
Well I'll tell ya, it is of course your own preference.
I use stock MC's and never had a problem. A good amount of the kits we have sold we have never installed a MC.
But of course you are probably swapping everything over to disc and from what I have heard and read the corvette one seems to be what the guys on here install, when going from drums to disc..
I installed a kit on my 3/4 ton and have yet to have a braking issue. It is also my daily driver
As for the emer brake we sell the bracket that attaches to the caliper to work with your cable.
There are a lot of options out there but thought I would jump in
You can check it out by clicking o the link in my sig.
Here are a couple of shots of it installed on my '72
Support The Board
drink2mny is offline   Reply With Quote
Old 09-28-2004, 02:59 PM   #5
chevy69er
would u use the prop. valve off a 78 vette too?
Old 09-28-2004, 03:12 PM   #6
drink2mny
drink2mny's Avatar
If i was going to upgrade from all drums to disc, I would probably just use a 3/4 mc or hydro assist. But thats what i have laying around..
Some people swap to corvette or other style, and some don't..
Mainly a trial and error item on our year trucks
Support The Board
Old 09-28-2004, 03:32 PM   #7
Mudder
Mudder's Avatar
I'm just running a regular old MC with booster for drums and I dont have any problems with mine at all. I have been driving it like this for about 8 years. I do change the pads regularly and get the cheaper pads. It stops great.
Old 09-29-2004, 01:31 AM   #8
BobbyK
BobbyK's Avatar
I used my orig. brake cable.I had to shorten it by about 2" though.I also had to make some small mods to the Eldorado e-brake bracket.
Problem I have found though is the orig e-brake pedal does not have enough travel to FULLY engage the e-brake.
It does engage,but it needs a smiggin more travel to have full e-brake pressure on the rotor.
Old 09-29-2004, 03:20 AM   #9
Budweis
Geared for Collision
Budweis's Avatar
i used the master cylinder and proportioning valve off a 78 vette on mine. also used the rod but had to turn down the end that goes in the booster just a few thousands as it fit too tight. also had to take about a quarter inch off the length of the rod. havent got it on the road yet but heres a pic and comparison pics of vette vs stock pieces.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 09-29-2004, 03:27 AM   #10
Budweis
Budweis's Avatar
heres a pic comparing the rods, the vette rod being on the left
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Old 09-29-2004, 09:28 PM   #11
chevy69er
Why did u change out to the vette rod?Would i have to do that if i use vette mc and prop. valve?
Old 09-29-2004, 09:30 PM   #12
Budweis
Budweis's Avatar
changed it because where it goes in master cylinder is different on vette mc and seemed like easier route to modify vette one as its two piece rod.
1970 C/K20 3/4 Ton
1977 Corvette Coupe
Thread Tools
Display Modes
