Old 09-28-2004, 07:02 PM   #1
Cliff
white smoke .....appeared today
Hey guys and gals. I was driving my 72 chev today with a 350/700r4 and i suddenly noticed a enormous amt of white smoke behind me. I have nothing irregular on my dipstick and my coolant level looks to be ok as well. I have true dual exhaust all the way back and the smoke is only comming out of the drivers exhaust. I'm sure it's not gonna be good news, but lets hear it fellas ? head gasket ? piston ring ? I dunno where to begin or if there are any little tests i can do to pinpoint this problem. Thanks everyone, you'll all are great. Cliff
1972 Custom deluxe 305/350 C/10 8-foot bed with 1/4 inch diamond plate steel bed floor.
Cliff is offline   Reply With Quote
Old 09-28-2004, 07:03 PM   #2
cableguy0
white smoke generally is coolant so i would do a compression test to check and see if theres a cracked head or bad head gasket. once you find which cylinder it is pull that head off and do a good visual then send the head out to be pressure tested and install with a new gasket
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-28-2004, 07:22 PM   #3
RON WOODGEARD
Resident Young Old Dude !
CABLEGUY, is right on... It's water somewhere, getting into the combustion chamber..
RON WOODGEARD is offline   Reply With Quote
Old 09-28-2004, 07:45 PM   #4
olblue60@aol.com
member
It could be just as simple as just the head gasket too. It happened to me a few years back
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 09-28-2004, 08:10 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Or a messed up block, like mine is.
Did you happen to run it hot today, or rev the crap out of it?
Old 09-29-2004, 10:28 PM   #6
mr402
One more thing to check. If your running the red antifreeze (dexron) and have left in in there a while it turns acidic. It will eat right through older intake gaskets.
mr402 is offline   Reply With Quote
Old 09-30-2004, 06:45 AM   #7
curbyk
69 C-10 project
curbyk's Avatar
You can usually tell which cylinder it is by removing the plugs, unless they are fairly new the coolant will steam clean them or they will have coolant on them.
69 C-10 Work is complete
curbyk is offline   Reply With Quote
Old 09-30-2004, 10:21 AM   #8
kwmech
Could also be just an intake gasket sucking the water into the intake port. Check the end cylinders first.
Old 09-30-2004, 07:15 PM   #9
Cliff
I pulled the plugs !
Hey everyone, sorry I haven't responded.. I'm at school and very busy and now the truck is smoking badly still lol. I pulled the plugs today and on the drivers side of the engine, the plug closest to the firewall was covered badly in oil. Infact oil poured out of this cylinder when i took the plug out I believe. I have a puddle under it now. I had a very hard time starting the truck today, it turned forever then finally popped and started before i ran the battery dead. None of the plugs were "steam cleaned" so I wanted to see where to go next with the oil covered plug. Will I find more clues if I pull the valve cover off ?
Thanks everyone.... Cliff
Old 09-30-2004, 07:26 PM   #10
cableguy0
wow that sounds like its burning oil are you sure the smoke isnt blue. sounds to me like either the rings are totally fu@!ed on that cylinder or you blew the headgasket and there is and oil passage there
Old 09-30-2004, 07:50 PM   #11
Cliff
re
the smoke looks entirely more white than blue, but that plug was for sure soaked in oil ARGH.....
Old 09-30-2004, 08:34 PM   #12
grayw0lf
If it were me, I'd hope for a bad head gasket.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 09-30-2004, 08:52 PM   #13
Cliff
re
would the bad head gasket cause oil leakage ? I'm hoping it's that as well.
Old 10-01-2004, 07:35 AM   #14
68C15
blood type; Retumbo
68C15's Avatar
do your self a favor & pull both heads for a valve job. that way you will have new gaskets, valve seals & good valve-seat sealing.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-01-2004, 02:17 PM   #15
Stryker67
Stryker67's Avatar
Hey all, I had a similar incident after rebuilding my engine and tranny in one of my '72's. I had white smike pouring out the passenger exhaust. It wasn't immediate at start-up, just after it ran a little while. After pulling the head on the passneger side TWICE, and finding absolutely NOTHING wrong, I was really getting upset. I called an old Chevy builder I know, and told him what was going on. He asked if the modulator on the tranny was replaced. I checked, and it wasn't. As it turns out, tranny fluid was being sucked up the line and into the intake vacumm port behind the carb. While I was happy to fix it for $5, I wasn't happy that I had missed the problem. Might not hurt to check that before tearing into the engine.
[FONT=Georgia]
If nothing else, we can all serve as a bad example.
We don't know what we don't know.
The world needs ditch-diggers too.
Stryker67 is offline   Reply With Quote
Old 10-01-2004, 04:04 PM   #16
Mixup
White smoke
He said he has a 700R4 and they don't have a modulator.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 10-02-2004, 09:51 AM   #17
Stryker67
Stryker67's Avatar
Oops.... missed that. Maybe this will help somebody else
[FONT=Georgia]
Old 10-02-2004, 11:30 AM   #18
ksamps01
I had a similar problem when I got my truck but I also had smoke coming out of the valve cover through the breather. I ran a compression test and had zero on #5 Cylinder. The rings and ring grooves were busted up.
Only option I had financially was to replace that piston. I would have prefered to do a full rebuild with machine work but, it has been running strong for almost a year. Maybe I just got lucky.(There's a first time for everything)
1967 Chevy LWB Fleetside
350/400 (Worn Smooth Out)
Resto in progress
It may be ugly but at least it's slow!!
ksamps01 is offline   Reply With Quote
Old 10-02-2004, 06:16 PM   #19
RON WOODGEARD
Stryker, That was a GREAT point though,, I forgot all about that one... Good catch !!!!
Thread Tools
Display Modes
