Old 09-29-2004, 11:35 PM   #1
kevinr1970
T350 to 700R4
I have an '81 GMC Jimmy (K5) with a bad tranny. I also have an '84 for parts that has what was initialy thought to be a bad tranny - the truck had a lot of engine work done, but when the guy got it back, the tranny wasn't working. When the guy that I got it from was pulling the engine he noticed some things for the tranny were not hooked up which made him believe the tranny might be good after all.
The '84 has no engine, but the tranny and transfer case are still there. Someone else had already pulled the rear drive shaft and the part of the tranny it connected to (the tail shaft?). Am I screwed with out these parts or will the parts on my T350 be the same?
My question(s) are this:
Will the 700 from the '84 go into my '81 (both square bodies) if I have everything from the '84?
Would they both use the same transfer case (208 I believe)? Can I unbolt the T350 from the transfer case, leaving the driveshaft in place, and bolt the 700 up to it.
If this is possible, will I need a different carb to match up to the kick-down linkage?
Anything else I should know?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 09-30-2004, 08:46 AM   #2
Jonboy
Slots go on anything!
They should both have 208 t-cases. if your case is still good, the 700 should (repeat, should) swap in place of the 350. You may need to use the 700 crossmember. The only thing I am not really sure of is the output shaft count on the transmission. It seems like it may be different between the two. If so, use the t-case hooked to the 700 now, and scavenge the tailshaft off of the other one you have. As long as you have the TV cable hooked to the carb and it is adjusted correctly, you should not need to change it out. You should have the correct stud on there already. Also, go ahead and pull the rear driveshaft out of your way. It's only 4 bolts, and it will make everything a lot easier to position.
1974 Jimmy- 5.3/4L80e/NP241
Thread Tools
Display Modes
