Old 09-30-2004, 02:05 AM   #1
TIMSPEED
TIMSPEED's Avatar
Fuel Filter: Supposed to always be FULL right?
I've been noticing this more and more lately. At idle, my fuel filter will have BARELY any gas in it. This means there's a restriction in the line somewhere right? It can't be between the pump & carb, cuz that's brand new rubber hose, and it can't be the pump, cuz THAT's new also (Holley 80gph mechanical) So it has to be between the tank & carb right?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-30-2004, 08:36 AM   #2
79Silv4x4
Workaholic
79Silv4x4's Avatar
I don't know if it should be full or not but mine is also not full.
79Silv4x4 is offline   Reply With Quote
Old 09-30-2004, 09:26 AM   #3
rockman20
"The dude abides"
rockman20's Avatar
Mine is not full either.
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 09-30-2004, 09:31 PM   #4
cochran63
cochran63's Avatar
mine fluctuates between some and full
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 10-01-2004, 07:30 PM   #5
leastbay
mine used to not be full than my valve for the dual tanks stopped working since fixing that its always full now and i had to adjust my carburetor afterwards too
leastbay is offline   Reply With Quote
Old 10-01-2004, 08:00 PM   #6
dott
dott's Avatar
The only way the filter can be totally full is if the outlet is at the very top. If the filter housing is laying on its side then the fuel will fill up to the top of the outlet opening. If the filter outlet is below the inlet it may look like there's hardly any fuel in it. This is normal.
'78 GMC 5.7L TBI, 4x4 longbed, 56" rears, 52" fronts
'01 F350 6.8L Crew Cab 4x4 Longbed
dott is offline   Reply With Quote
Old 10-01-2004, 08:12 PM   #7
1972C10
1972C10's Avatar
I used to run a mechanical pump and it would be low to almost emtpy at times but if i ran the engine wide open for awhile it would be plum full.
I converted over to an electric pump and it stays full
1972C10 is offline   Reply With Quote
Old 10-02-2004, 01:50 AM   #8
TIMSPEED
TIMSPEED's Avatar
I'm considering doing this. I WOULD say it would need to STAY full..but that's what the bowl's are for.
See Them Here
Old 10-02-2004, 10:53 AM   #9
1972C10
1972C10's Avatar
Yea its not a nessacity I ran mine on a engine driven 81 camaro w350 and ac fuel pump has a larger resiovoir Other than that is stock as far as i know.
It ran fine just had the space in the filter when it idled and hadnt been driven much,
Old 10-16-2004, 04:10 AM   #10
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Red face
Mines mounted horizontally and it has barely any gas in it at idle too.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 10-16-2004, 09:31 AM   #11
Mike76251
Oh my, this is a oldie!
This question has been around 40 years (that I know of).
I have noticed this on many engines I have come across and it seems to be a normal thing. Happens on my lawnmowers, welding machines, and all the cars with glass filter bowls that I have.
Bottom line.........don't worry about it if it runs. Worry when it comes "uncranked".
Mike76251 is offline   Reply With Quote
Thread Tools
Display Modes
