Old 10-03-2004, 12:47 PM   #1
60apache4
disassemble tilt steering column
I need to know if there is an easy way to disassemble a tilt steering column. The column i bought did not have them , so all I need to do is put on the dash seal, firewall seal and retainer and they won't go on over the shaft and auto shift linkage. Thanks for your help...Tom.
60apache4 is offline   Reply With Quote
Old 10-03-2004, 12:51 PM   #2
60apache4
I also need to know if there are supposed to any shifter detents mounted to the column tube. My standard auto shift column has a tab with several steps in it to prevent shifting back up into reverse...Thanks again.
Old 10-03-2004, 01:59 PM   #3
neonlarry
neonlarry's Avatar
You do not need to take the column apart just bend the linkage enough to slide them on.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 10-03-2004, 05:09 PM   #4
john
member #16
john's Avatar
The detents are inside the top end of the tilt column. John
john is offline   Reply With Quote
Old 10-09-2004, 12:34 AM   #5
60apache4
I need to remove the steering shaft and or shifter tube just to get the stupid firewall seal and retainer on the steering column.
Old 10-09-2004, 06:12 PM   #6
60apache4
Well then, how do you remove the retainer ring and bolt from the upper part of the steering shaft? I don't see how the retainer ring comes off and it is not explained clearly in the shop manual. Thanks.
Old 10-09-2004, 06:43 PM   #7
JimKshortstep4x4
Smile
I am not sure what you mean about the retainer ring and bolt. What are you trying to take apart?
If the detent does not hold, there is a good chance the shift lever spring is broken and/or the end of the shift lever is worn.
Jim
Thread Tools
Display Modes
